Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlian garge door opener only closes by holding down wall push button,no lights at safty sensors
  • 504 Answers
Probably a broken wire to one of the sensors. Holding down the wall button overrides the sensors.
If you move the wires at the back of the power unit and at the sensors watch for the sensor lights to flicker. - If they do the wires you just moved are the problem.
If moving the wires doesn't help you will need to trace the wires & watch for a broken wire loose connection etc.
Hope this helps
Posted on Aug 22, 2010
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
Garage door won't close unless I hold down the wall button until it is fully closed. Checked the L.E.D light at motor and it flashes 2 times in about 8 seconds. Sensor with amber light is on, other does...
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
Oct 09, 2010 | liftmaster Chamberlain Garage Door Opener...
My craftsman 1/2 hp garage dood does not close when it's cold out (with either a push on the remote or a single push from the wall). I have to hold the wall button in until it's completely down. When I do...
Make sure the brackets for the sensors are tight and the small light on the sensors is not blinking ever so slightly. You also might try shading the sensor so that the sun is not shining directly into the lens.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need wiring diagram for eyes that control safty device door willnot close by one button push , have to hold button to close , light on opperator has one flash
Safety reversing sensors wire open (broken or disconnected).
Each sensor has a solid white wire and a white wire with black tracer.
The solid white wires go to terminal 2 and the wires with the black tracer go to terminal 3.
Jan 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener 1/2 hp about 6 years old. Will not respond to remotes to open and close. Light flashes on opener when remote is pressed but no door action.
Door sensors are not working. Check if lights are on both sides.
Might be misaligned or one is bad.
Door will close if you hold in the garge close button until it's all the way down.
And it will open on it's own.
You can get these off ebay.
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close w/o holding down push button on wall
Check the door sensors. They must be properly aligned to work. Both of them has a small light that must be lit and will only light when they are pointed at one another.
Aug 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THEY AIMED AT EACH OTHER?
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Wayne Dalton garage door will open with remote but not close. The only way it will close is to hold down the wall mounted garage door button. Then the light goes on and off while clicking. I have...
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
87 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
