Hello,I have a Vector Smart 12V battery Charger#1093A.I kept it under the shead with my boats.I may have used it 20 or 25 times. I would like to know where to send for repair.I did look around for a fuse but chould not find one. I don't feel I got what I payed for.Can someone help and old man,get his batteries charged up. With out being over charded:I had to sat it! Thank you,Whiskyjoe P.S. My zip is 29431.
    Problem Solver:
  • 22 Answers
Me too
Posted on Jul 11, 2008
How long does it take to fully charge a vector smart battery charger? When I unplug it, it won't power on unless it is plugged in. it is a VEC 1092 a model
The initial charge can require several hours, sometimes overnight. After that, recharges require less time. If your device doesn't turn on unless connected to the charger, the battery may be dead.
Apr 18, 2016 | Vector Camping, Backpacking & Hiking
How would I go about getting a charger
Depend on what kind of batteries, and how often you are going to use the charger, and for what purpose are going to use it.
If your battery accidentally discharge far from your home a Jump Start is a must. But Car batteries are shallow Cycle and need to be fully charged. If you want to Set and Forget Charger, then a Smart Charger takes care on his one for the battery. Automatically adjust the voltage and turns off when the charge is completed. Has the Reconditioning option, can display the battery voltage, and can check the alternator. Destroying a $120 battery is more expensive than a Smart Charger.
I use a Vector Smart Battery Charger - 2/10/20 AMP 12V fully automatic.
Retail $49.95 I bought on sale CLEARANCE: $29.95
If you have cars not driven in daily bases, or go in vacation, a battery Tender is a good option too.
May 20, 2015 | Vehicle Parts & Accessories
I need a power charger for a veco 12 pod 450 amp 12 volt jump start system .
The smart thing to do is, after using it for a jump start, leave it connected for 5 minutes and it is charged again... otherwise a normal 12 V charger will do on the clamps that go to the box... I use a 12V Stanley 25 amps when needed. But most of the time I keep it connected for 5 minutes and do not worry about it.
Jun 23, 2014 | JUMP START SYSTEM
How do you use the vector start it pro to charge a battery
The overall verdict is this is a poor quality jump starter which has an unreliable charger and a battery that will die if you don't look after it. However, I found one fair report on Amazon amongst many bad ones:
"The compressor on this unit, like so many others this small, is really only made for pumping up toys or bicycle tires. So don't buy this unit for that purpose. Go to a gas station with quarters and use their air vender.
If, like me, you bought a used unit, you will need to get both the manual and the charger. Do a search on servicenet dewalt to find the owners manual. The manual is a download pdf. Charger model number is 514005-42.
Hope this helps. It's really a neat little device to have around. I especially like the built-in LED flashlight.
You really NEED to read the manual all the way through. The special sealed type battery requires charging at least every 60 days or it WILL go bad quickly."
The Manual is here: http://documents2.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC010BD.pdf
Because I'm an engineer I know I could easily replace the 12v lead-acid battery charger, open the box and replace the battery with another 12v say 200 Amp cranking (short circuit effectively) battery but I would tend to spend a bit more on a gel battery of similar spec 'cos it basically is the only sort that should be used for deep cycle discharge with such a small volume battery. Good luck.
Jan 25, 2014 | JUMP START SYSTEM
What does F01 code mean on a vector vec1097A smart charger
F01- Internal Shorted Cell Battery-(Cannot Be Charged) or
Excessive Load On Battery While Charging (Check Load)
*If this shows it is recommended to take your battery to a certified auto center for evaluation.
This Info Came Directly From The Manual.
May 02, 2010 | Vector Black And Decker High Frequency...
Can this equipment be used bidirectionslly? i.e.
you can use an invertor to power a battery charger to charge the boat battery but you could not use the invertor to charge the battery it was running from as the invertor will use power faster then the battery could be charged
Apr 05, 2010 | Vector MAXX 400 Watt Power Inverter -...
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Feb 20, 2010 | JUMP START SYSTEM
Spot light is unable to recharge with the wall
While it could be the battery, it could also be the internal charger in the spotlight. When you plug it in, it bypasses the charger and uses the connected power. However, it is likely just a bad battery. The batteries only last 3 years in an ideal setting and since these lights are typically only used certain times of the year, the batteries discharge and go bad. New batteries can be found at: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jul 18, 2009 | Vector 3 Million Candlepower Rechargeable...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
