Question about Brother MFC 4800 All-In-One Laser Printer
Cannot reset the change drum soon message after replacing drum.
Have tried leaving cover open and pressing options, but it just tells me to close cover!
    Sergeant:
  • 287 Answers
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
This message would continue to appear if the clear plastic starter sheet was removed from the "new" drum before it was installed. This plastic starter sheet, resets the drum counter. To reinstall drum with the starter sheet, please follow the instructions listed below:
Locate the starter sheet. Clear plastic sheet, 9 inches long, with a cut out in the center. The sheet will have "Initialization of your new drum successfully completed. Please discard this sheet" written on it.
If you cannot locate the starter sheet, contact the Brother Customer Service or the appropriate Brother authorized dealer.
additionl info HERE
Posted on Jul 11, 2008
How do I reset the "Change Drum soon" Message
Open the front cover
Press Option
Press "1" for yes
after that, close the front cover and you are ready to use again.
Feb 22, 2011 | Brother MFC 7420 All-In-One Laser Printer
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
Can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Not accepting new drum
remove and replace the drum unit, but leave the cover open. You should get the message "replace drum unit".....YES | NO? press "1" to reset. after it says "accepted", close cover.
Please rate me :)
Mar 29, 2009 | Brother MFC 7420 All-In-One Laser Printer
Compatible drumunit brother fax 2920
Mar 23, 2009 | Brother FAX-2920 Plain Paper Laser
"Change Drum Soon" Message; not change when we changed the drum.
Description:
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Jul 08, 2008 | Brother Office Equipment & Supplies
Change drum soon will not clear after new drum inserted
Reset of the drum counter
Hope this helps...
Jun 10, 2008 | Brother IntelliFAX 2800 Laser Fax
Drum on Brother MFC-7420
Why does the message "CHANGE DRUM SOON" continue to appear on the LCD display of my Brother machine, after I replaced the drum? Description: This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below. Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
Jul 27, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 4800 All-In-One Laser Printer Logo
948 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
