Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Tv tuner installed the product. no sound on computer.
Al instalar el driver y el software no tiene sonido
Posted on Jul 15, 2008
Not install software SAA7130 TV Card Please Help me for your download software. thank you
I have a honestech TVR Tuner card (Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture) on my *other* computer. I can watch tv no problem, i see stuff, and there's audio. But when i record, i can only record image, no sound. It asking for digital singh and not instaling praperly
Aug 03, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
I'm looking for a tv tuner for my motherboard p56c-mx/gbl and how could I connect it?
There are several options for you to get a TV tuner for your computer. You can either use a USB tuner, such as this: http://www.newegg.com/Product/Product.aspx?Item=N82E16815260023&cm_re=tv_tuner_usb-_-15-260-023-_-Product
Or you could connect a TV tuner card via PCI express, located on your motherboard. An example of a product that would do this is this: http://www.newegg.com/Product/Product.aspx?Item=N82E16815100041
These will come with software for you to use so that you can browse your favorite channels on your computer!
Mar 01, 2011 | Computers & Internet
Intex tv tuner card SAA713x and computer sound on one point
this will make your life alot easier
http://www.radioshack.com/product/index.jsp?productId=2103863
best way to do it bud
Aug 20, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Getting windows media to work with tv tuner card
its is due to the older tv tuner card drivers doesnot supports for windows mediacentre try to update driver if not change for new tv tuner card which supports mediacentre.
Feb 24, 2008 | Creative Labs Sound Blaster Live! 5.1...
Tv Tuner & Sound Card
Hello!
Please install the driver of your soundcard, If you have Cd utilities enclosed onto you computer please install the all the drivers, from chipset, vga,souncard or audio so that all the problems wil be resolved.
i f you have none cd utilities then tell me your mainboard(model number) sothat i can search driver for you to download.
hope this help
best regards, melnavz
Feb 20, 2008 | Intel Motherboard
Using tv tuner card for a s/w
HI,
PLEASE CHECK UR CARD OR TRY TO RENEW IT OR PLEASE CHECK UR SOFTWARE IN THE WHICH EFFECT THE EXTRA TERESSTIAL THING SOFTWARE LIKE - FIREWALL.
Jan 29, 2008 | Computers & Internet
No visual
Support for this product is terrible. I went onto Phillips website and this model number doesn't show up. I bet someone like Pinnacle Systems made one for them but you won't know unless you call them:
1-919-573-7854
There open on Sunday too until 9:00 pm EST
Aug 21, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
I am having problem with tv tuner card
i think your tv tuner is defective even if it is new, still factory defects can happen. try to install it in another computer, if you experience the same problem then it is defective. but have you checked your device status at device manager under sound, video and game controller. if you see a yellow apostrophe or a question mark it indicates that your tv tuner is havent been installed yet. try to double click the device and you'll see update driver then try to intall it by choosing automatically driver, be sure that the cd driver is inside your cd rom.
Sep 18, 2006 | Philips TV Tuner Video Capture PCI Card -...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
