Question about Whirlpool Dryers
Dryer won't start when you hit the start button -
  • 525 Answers
Based on the information provided above, I am unable to provide a positive solution to your issue. I have provided some common solutions to help guide you in your search.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Clicking on the underlined links will take you directly to that page.
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you have a volt-ohm meter, you can test the voltage, 240 volts is required to run an electric dryer. Check for a blown fuse or tripped circuit breaker. If you have fuses, replace BOTH fuses. If you have breakers, turn off the breaker and turn back on.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 11, 2008
2 Suggested Answers
  • 185 Answers
SOURCE: My DLG5988W dryer won't start. The lights come
sounds like a electronic board failure.
Posted on May 16, 2011
MEDC400VWO Electric Dryer won't run
Have you got power going into the machine?
NUMBER 7 is the fuse you must remove the wires to do the check
My page of this type dryer
Sep 04, 2012 | Maytag Dryers
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
I hit the start button and it will not start.
You will need an ohm meter to check but most likely cause is a small white fuse inside the back. Lower left side near the blower wheel.
May 21, 2010 | Whirlpool LER4634J Electric Dryer
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Dryers Logo
190 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
