Question about Brother HL-5240 Laser Printer
Red light stays on and will not print
The red light stays on.  When it turn the printer off and back on, the green light comes on and then turns red.
  • 4 more comments
  • kkicia Oct 16, 2008
    I cannot print at all, when recycling the power the status light turns red, if I press the cancel job light it turns green but still cannot print, not even a printer test page. I tried replacing the tiner & fuser & reset the counter without any success, any other ideas
  • mmneal1 Oct 31, 2008
    The paper jammed. I removed the paper and now the status light is stuck on red and the printer will not print anything.
  • Anonymous Nov 08, 2008
    please help if you know the answer
  • Anonymous Dec 29, 2008
    status light is red. when i turn it off and then back on the green light comes on and it powers up, then powers down and goes back to red
  • stuhar Jan 13, 2009
    paper jammed. I removed the paper, status turned red. Will not print.
    Checked paper tray, toner, back opening, nothing changes status.
    Turn off, then on, it starts to turn on then status light turns red.
    If i press job cancel, turns green but won't print.
    Cant print a test page.
    The computer sends the print job successfully, but no print.
  • Anonymous Jan 14, 2009
    Though we opened the back, as suggested, there was nothing stuck there. Sigh!
There is a second piece of paper stuck in the machine.
open the back flap, look at the diagram, and pull out a piece of hardware
behind this hardware, all crumpled up, not visible, is a jammed piece of paper.
Posted on Jan 13, 2009
Red light is on. It is not blinking, it is solid on. no paper jam, all doors are closed. I took the cartridges out went back and force with them, and put them back. Help !, the warrenty just expired last...
if there is no paper in the printer the red light will stay until you put some on it, make sure that when putting paper it goes all the way until the end and the red light will turn green, then you can print.
Mar 04, 2011 | Samsung CLP 315 Laser Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
Epson 2400 problem
Maybe your epson printer has reach the printing warranty.. try to reset your printer by using SSC epson printer resetter.. ^^ cheer..
Mar 13, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Jul 22, 2008 | Brother HL-5240 Laser Printer
Samsung Printer CLP300
Have you run the Dr. Printer utility that comes with the printer? If not, run that and see what it says. You can download it from the CLP-300 support page at samsung.com.
Apr 30, 2008 | Samsung CLP 300 Laser Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Brother HL-5240 Laser Printer Logo
661 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
