Question about ASUS S478 VIA P4V533-MX Motherboard
Motherboard problem i can boot to cmos setup. but if i save it, it won't boot anymore
  • 983 Answers
I think the bios is corrupted ...
just change the bios jumper to the recovery mode in the motherboard ...
the information on how to change jumper to the recovery mode you can just refer your motherboard manual .....
after recovery you must replace the jumper to the normal position then after that the bios will boot & you can save it ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution ..
Posted on Jul 11, 2008
Won't keep boot setting
This might be a problem with the cmos battery either not holding charge and running flat or not securely seated with dust between it and motherboard although some motherboards cmos batteries are soldered in
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Nov 17, 2012 | Computers & Internet
Bios not save
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Bios setting are saved in cmos batteries
make cmos battery has charge and is not loose
cmos battery images
http://www.bing.com/images/search?q=cmos+battery+images&qpvt=cmos+battery+images&FORM=IGRE
hope this helps
Oct 11, 2012 | Computers & Internet
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Would like to reset CMOS on inspiron 6000 - will not boot up to BIOS How do I reset CMOS
scroll to load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart this will reset your cmos after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS or
you will need to remove the cmos battery for 15-30 mns this will reset your cmos
im not sure where its located on this motherboard or whether its soldered in
hope this helps
Aug 08, 2011 | Dell Inspiron 6000 Motherboard - W9259
Hi, I'm using Asrock P4I45GV R5 Motherboard. but when i attempt to install OS, it shows NTLDR Missing. but HDD is working properly. at the next time when i try to boot from the CD it fails. and i need to...
just go to in bios setup using F2 or del key and change the booting sequence.and set 1 cd-rom 2.hdd
now save and restart system now you are able to boot from cd rom r dvdrom
Apr 10, 2011 | Asrock P4I45GV R5 Motherboard
Cmos checksum bad
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
don't forget to vote
Feb 11, 2011 | Computers & Internet
I can't find the CMOS
hope this helps
Dec 28, 2010 | Dell (04U621) for Latitude D600, Inspiron...
Cmos settings incorrect press F1 for setup. Replaced the cmos and reset jumpers and still the same problem.
bios setup F1
make sure you load optimal/default settings and your hard drive primary/Operating system drive boots first F10 save ok enter
Jul 04, 2010 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
It doesn't boot from hard disk
can you still go to CMOS SETUP?
how many beep and beep long of your pc while booting?
if you can still go to cmos setup try delete all partition using your windows setup then install a fresh copy of windows. if there are no partition found means theres a problem with your hardisk try put your hard disk to secondary if in primary or use different data cable might be the problem if the data cable is not the problem see the power supply of your hard disk is fine try swap the power suppply of your hard disk and cd-rom drive or extra power supply if power supply is not problem .
Buy a Brand New Harddisk might fix it your hard disk might have plenty of bad sector thats why doesn't boot anymore.
Hope i help you out ^)^
Jul 01, 2009 | ASUS P4SGX-MX Motherboard
Boot from usb
try to disable the other boot device, or you simply need to first boot the usb then the rest disable.... if the problem still occur, you might not save the setup utility options properly or the flash bios/cmos failed to save due to a weak or a cmos battery checksum error...
Nov 10, 2008 | Matsonic Computers & Internet
ASUS S478 VIA P4V533-MX Motherboard Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
