Question about Saeco Incanto Classic Espresso Machine
Steam not frothing milk
It seems that the steam from my coffee machine (incanto deluxe), has stopped frothing my milk, it will heat the milk, but it heats it slowly and the milk won't froth, the machine is also making a strange bubbly sound. I have cleaned everything out thoughrily and am not sure what the problem could be. Any ideas of what I can do to fix this?
  • 3 more comments
  • Anonymous Jul 14, 2008
    I have this same problem. I recently ran through the decaling cycle when the machine gave the signal that it was time to do so. I think it helped but the milk frothing still isn't as good as it used to be. Is there a way to program the machine to start another descaling cycle?
  • eklc Jul 17, 2008
    unfortunatly descaling didn't help - any other suggestions? - thanks again for your suggestion
  • lakernopine Jul 21, 2008
    I also had that bubbling sound and the milk was not frothing so tokk off the pannarello cover (cover on the steamer) and cleaned it. In the process the black "guts" from the cover came out. I pushed it back into the cover making sure it went all the way in and after that the steamer frothed my milk again. I have no explanation for this but that is what happened!
  • Anonymous Feb 06, 2009
    I have the same problem. I Unscrew and clean the “pannarello” attachment but that didn't seem to help. I also cleaned the nozzle opening with a needle. I'm still not able to froth the milk.
  • Anonymous Mar 12, 2014
    nespresso delonghi coffee machine chills milk instead of heating, Used to work beautifully until this morning please help
I had the bubbly sound too and no frothing. I took the cover off the steamer and cleaned it. In the process the "guts" from the cover came out. I pushed it back in making sure it went all the way in and after that I got froth again. I have no explanation but that is what happened!
Posted on Jul 21, 2008
  • 515 Answers
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Posted on Jul 11, 2008
  • Mirko Blas
    Mirko Blas Jul 17, 2008
    Make sure your pannarello is clean and that the nozzle at the end of the steam pipe is ok.
    To start a second descale you have to hold in the button with triangels on.
I cant get my steam wand to froth milk- it heats just fine, just wont froth.
The steam valve can wear plastic on metal, try pushing on the knob while steming , if the steam pressure increases the valve is worn out and not opening all the way.
Dec 24, 2014 | Saeco Incanto Classic Espresso Machine
Delonghi perfecta milk not hot enough
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
May 31, 2014 | DeLonghi ESAM6600 Espresso Machine
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Seaco Incanto not frothing milk properly
Hi
When was the last time you descaled the machine, and not with vinegar? Scale can accumulate inside the boilers and insulate the water from the heating elements, produce less steam. Descale on a regular basis.
May 12, 2009 | Saeco Magic De Luxe Espresso Machine
I have my Incanto Deluxe for about 1 year. I have never had any problem making a good quality froth, but recently the frother is producing too much air and milk is becoming bubbly. I am religesly clean my...
I think you have a chrome steam wand end.
To froth properly, there is a very small hole on the side of the chrome steam wand that injects small bubbles into the milk, the hole is located aprox 1/4" down from top of the chrome wand, if this hole blocks up you can only heat the milk, not froth. I commonly use a stripped tin tie wire or a sewing needle to clear the hole . Clean the hole,do not enlargen the hole.
Mar 02, 2009 | Saeco INCANTO DELUXE Espresso Machine
The mahine does not froth the milk properly anymore
alisha165,
the saeco royal digital dosn't froth milk.... it produces steam, you are the one that froths the milk. is the machine still producing steam? if not you will need to have your steam boiler replaced. This should only be dune by a qualified repairer. If it is still producing steam but it is not as good as it use to be, descalling you machine may help.
Sep 29, 2008 | Saeco Royal Digital Plus Coffee...
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Brand new Incanto Classic bought online, not working after 1 month
First, machine should be under warrantee- check with 1800myjuicer.com
Sounds also like you have blockage in the steam wand- every time you froth milk, you should let some water come out- to prevent clogging. Try first inserting a pin into steam want ( machine turned off) to see if that alleviates the problem. Also contact
Saeco USA Inc.at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 17, 2008 | Saeco Incanto Classic Espresso Machine
Steam and froth malfunction
The milk can not be room temperature.  It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
Feb 18, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Saeco Incanto Classic Espresso Machine Logo
958 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
