Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Just bought tv. No instructions on removing base for wall mounting.
I DON"T UNDERSTAND HOW TO IMPLEMENT THE SOLUTION THAT IS GIVEN IN THE FIXYA DATABASE.
PLEASE CLARIFY THE SOLUTION....DON'T JUST REPEAT IT!!!!!
  • Anonymous Jul 22, 2008
    I have no instructions to remove base and cannot figure it out. Insignia 26" LCD? Can't get the silver swivel thing off!
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Posted on Aug 18, 2008
Where can I buy a base/stand for my insignia ns-lcd47hd09
This is a common problem. You can try to get one from the supplier but you can also search the internet for a universal replacement
Feb 22, 2013 | Insignia NS-LCD47HD-09 47 in. LCD TV
Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
May 29, 2009 | Insignia LCDTV26 26 in. Television
Removing television base
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Mar 20, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Televison & Video Logo
1,050 people viewed this question
Top Televison & Video Experts
Electro Med Services...
