Need a replacement fan blade for Tatung Mod. #LC 12 desk fan. Any chance??
3 Suggested Answers
  • 4736 Answers
SOURCE: I have a Model MOD-CAT-23785-380
Davd the "arm" is technically a "Blade Iron". You can find them at most Home Improvement Centers (Lowe's & Home Depot) as they both sell Hunter Fans and universal parts.
Hope this helped you and thanks for choosing FixYa.
Posted on Aug 09, 2011
damneddle
  • 1607 Answers
SOURCE: I need a new fan
Hello.
Have you tried ordering from the manufacturer? Here is their contact information:
Tatung Contact Info
Posted on Aug 07, 2011
Where is the fuse for a comfort zone model cz121b ocillating desk fan?
I've never seen a fan with a replacable fuse. There may be a thermal fuse inside the motor windings.
Jul 17, 2014 | Comfort Zone 12 In Oscillating Table Fan -...
I have a Model MOD-CAT-23785-380 Ceiling Fan. I broke the arm that holds one of the blades. I need a replacement.
Aug 09, 2011 | Hunter Heating & Cooling
Hai I'm Prem here that my lc nuovo go sound around fan coolend area like very noisy and vibration thx
With the engine cold, check the fan blade assembly for cracks. Some blade assemblies have a large ring or band around the outside of the blade tips. If it is broken the fan becomes off-balance while spinning and will vibrate badly. Fan replacement will likely need to be done to cure this problem.
Jan 06, 2011 | Yamaha V-Max Motorcycles
A broken blade on our Hampton Bay Brushed Nicel Romano
you can call air cool, they manfacture and service the fan. 800-896-4908 price as of 7-12-10 was $12 per blade and $30 for the set of four. manual is $5 as well
Good Luck
Oct 22, 2009 | Hampton Bay 52 In. Brushed Nickel Romano...
Desk Fan needs a nudge to get started
your fan motor brushes have worn down to the degree that they need to be nudged to work. you could replace the motor brushes or just consider the trash can.........up to you.
Aug 13, 2009 | Dryers
I Have a hampton bay ceiling fan mod. 523 342,
if you have connected power directly to the fan motor and it doesn't turn...replace the fan.  However, also check the switches on the fan as you may have bumped them.
Mar 24, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
Jul 11, 2008 | Kitchen Ranges
Fan Blade Wobble or Part of the Design?
The problem you are getting is due to a warped fan blade, assembly of motor, or unbalanced spin radius. Your best bet on this is to seek a replacement from your manufacturer, as this is likely a fault of the assembly process, or even of manufacturing the fan blade set anyway. While the problem is not a major one, and you will be just fine using said fan for some time, it will shorten the life of the motor, which will eventually run dead due to extra stress. To prevent excess wear and tear, run the fan at a slightly lower speed, i.e. on 2, maybe even 1. At higher speeds, the centripetal force will cause the blades to warp further, and pull the motor back and forth, and thus, cause the unit further damage.
Jan 11, 2007 | Lakewood R12-DSK Table Fan
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
