GE washer model WBSE3120B2WW has electronic control assembly replaced. Unit will not start, all lights on panel are green and blinking.
  • 2 more comments
  • Anonymous Sep 25, 2008
    I have the same exact problem! have you figured it out?
  • intheskyrn Sep 30, 2008
    Same exact thing here! was told the electronic board needed replacing, and so we spent 100.00 dollars and still nothing. i am so mad.
  • tiffanyb919 Nov 13, 2008
    Sorry was not ment to be a solution. No time to wait on slow computers.
  • Anonymous Mar 15, 2014
    replaced the control and can not get to start
I have a very simular problem. It started by running a cycle without me even being in the room. The only way I could stop it from filling and running through a cycle was to unplug it. I left it unplugged for about week & 1/2 - 2 weeks and when I plugged it back in, it worked just fine. It has started running by itself again but now I push the start button and nothing happens. Any solutions?
Posted on Nov 13, 2008
Ge washer WBSE3120B2WW. Washer stops at random places in the cycle on all wash settings. Sometimes it'll start and immediately shut back off. Used to be unplugging it between washes helped.
Great diagnosis for "do it yourself", go to:
www.repairclinic.com
Add your machine model number and look for your specific issue. They have videos that are of great help.
Nov 01, 2016 | GE Washing Machines
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash. http://www.appliance-repair-it.com/ge-washer-lights-blink-after-replacing-the-control-board.html
Sep 13, 2010 | GE WBSE3120B Top Load Washer
GE washer model WBSE2090A0WW control assembly replacement
hi. I was also searching for the same part and got the same result; nooo, the unit is smaller and only has spots for two knobs not four.
have you looked at this site? https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=PARTSRESULTS&AppliancePart=Washers and Dryers_Miscellaneous .... if that link doesn't work try this and navigate thru it.
There is a guy who lives down the street from me who owns an electronics repair shop; I will be taking my control assembly to him. I'll let you know what he says. On my circuit board, there is a "brown" solder joint; all others are the normal silver color. Hopefully the guy can fix the component that hooks up to the solder connection (it's a relay).
I've been having trouble w my washer (same model as yours) for a couple months ~ I've troubleshooted everything!!!
Hopefully we don't have to end up buying new washers!! take care. (I'll let you know what my neighbor says, too ... thx)
Jan 02, 2010 | GE Washing Machines
Ge washer wbse3120b2ww does not fill water and go to the final sp
hELLO THERE
well it is looking like you have a water controle solinoid valve that is malfunctioning and needs to be replaces i would contact your nearest dealer to see what the part is going to cost and have it replaced and if you have a warranty with the machine see if you can use it .
best of luckmike
Jul 31, 2009 | GE Washing Machines
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Washing Machines Logo
606 people viewed this question
Top Washing Machines Experts
