Question about GE WBVH6240F Front Load Washer
GE Washer shaking
I was wondering what you mean by you 'shearing' the floor to help the shaking of your washer. Could you explain the process? Can anyone, (even a household wife) do this? By the way, did you ever find another solution? Thank you.
    Novelist:
    Champion:
  • 261 Answers
Check this first: level of machine and all feet secure. Is the machine on a pedestal and is it securely fastened? Are your clothes wet after a spin? I know I stress drain height and hose placement, but todays washers are power misers and this means smaller motors. A pump needs some give at the drain, a slight gap like an old dishwasher so it can pump easier. I feel some water is in the machine and not draining in time causing a vib during spin.
Posted on Sep 11, 2008
Shaking GE Profile Washer
level the machine and make sure the floor is sturdy, you can even put a piece of plyboard under it.
Feb 05, 2014 | GE Profile WPRE6100G Top Load Washer
Washing machine is really loud when spinning (sounds like a plane taking off)and if you are sitting on couch one floor down you can feel the couch vibrate and the floor its on shakes like crazy. I was told...
no it is not normal and there so be no reasonable excuse for bad vibrations and shaking on a new machine ,if the setting up instructions and leveling procedures were carried out.
at six months it should be still under warranty so have it fixed under the warranty
Apr 23, 2017 | Maytag MHWZ400T Front Load Washer
Shaking and moving washer
my washer shakes when its washing clothes
May 23, 2010 | GE WPXH214A Front Load Washer
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Washer shakes terribly in spin cycle
Does the floor or the walls shake? If they do you have to beef up the flooring under your washer, with blocks between the floor joists, piers, or sistering of the joists. If there is no shaking of the floor or walls, and your washer is solid on the ground, leveled and not rocking, then it is your washer. Lg has problems with too much vibration in their washers. Check to make sure that your lint filter/coin catcher is clean. Open the door in the bottom front, put a towel down to catch the water, Unplug the washer, and unscrew the large plastic screw that is the filter for your washer. If this has debris in it clean it out completely. Look in the hoses also, if your water drain is restricted by lint or coins or other debris, the washer has clothes in it that are wetter and heavier than they should be, and this will cause sever vibration. Good Luck, Appliance Specialists
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Whirlpool Kenmore 80 Series is making loud noises during washspin
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Jul 05, 2009 | Washing Machines
GE front loader shakes when trying to spin
try putting either a piece of plywood under the machine so that all 4 legs are standing on it or using plastic floor protectors that fit under each leg to see if you can get it to be more level. Have you ensured that each leg is in full contact with the floor?
Feb 06, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Excessive shaking during spin
hi thanks for the question is the washer on the main floor on a wooden floor if it is re level washer next pull washer towards you tipping towards you lift from floor a few inches and let drop to floor this will re level the back legs thanks the appliance doc
Mar 17, 2008 | GE Profile WPRE6100G Top Load Washer
GE WBVH6240F Front Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
