Question about Goodman CLJ30AR32 Air Conditioner
Air conditioning unit
Copper pipes are iceing over. I shut it off and they melted. so I turned it back on and it was working but now the pipes are iced over again.
  • abryant09 Jul 28, 2008
    My ac unit was replaced 08/07& when it was replaced, it cost $1600. It would have an additional $1000 if I had also replaced the coils. My pocket opted not to do that. After the initial install my home still wasn't cooling, so they came back out and checked the unit then added more freon. It then started cooling the house. In 07/08 I'm having the same problem of my unit not cooling. The same company came back out & he stated that I have a slow leak. I can either pay $1000 to replace the coils or he could add freon & it would cost me $118. I opted to pay the $118. My coil outside now has ice on it again. I've turned only the fan on to let the ice melt and also changed the filter. It started cooling but after a while the ice came back and my home is hot again. What should this company do for me to fix my problem. I don't have $1000 to replace a leaking coil and I definitely can't keep calling them out to my home to add freon every other week. Isn't there some type of warranty. I never had this problem with my old unit. What do you suggest?
  • Goodman Master
  • 1,236 Answers
On a "Non Heat Pump" unit, icing of the pipes is not good. It is an indication that you either have a low freon level (Charge), low load, wrong superheat.
A low load usually means, in this case, something wrong with the air flow. Clogged filter, wrong fan speed, something blocking the return air grill, like a chair/ blanket, etc.
If low on charge, the evap (Indoor Coil) will ice up and the ice will then slowly creep along the pipe untill it gets to the outdoor unit. This is really no good. Air cannot go thru solid ice so naturally there is no cooling happening.
If a company replaces the outdoor unit (Condensing Unit), there is no warranty on the indoor unit. I do not know of any company that will repair an indoor coil (Evap). Just not smart money. They have to capture the freon, open the system, make the repair, ensure the correct level of freon is in the system, and most time, add a filter/ dryer for additional filtering and drying of the freon. With all that, no one is going to patch a leak on an old coil because if it leaks now, it's going to have another soon. You'll just be chasing leaks and spend money after money. Hope that makes sense. HVAC companys have to follow the EPA rules too. Leaving a system leaking above a certain percent of it's total charge is a major no-no. They will not do it.
Hope this helps clear up a few things and good luck.
Posted on Mar 20, 2009
My central air AC unit (Double wide home) always works for generally up to two hours, then it freezes up, by the copper pipes ice over, shutting them off and letting them thaw out, works to get it going...
You are absolutely right! The copper pipes should have insulation them. When they don't and they get cold in hot weather, they sweat and then freeze. Tubular Foam Insulation is what you need. Most home centers carry it. Once you cut and install it, be sure to wrap it in a good quality Duct Tape.
Hope this helped you. Good luck.
Jul 15, 2011 | Coleman Heating & Cooling
Water dripping from internal unit of J.B.S. split system air conditioner
This can be due to three reasons. The water drain pipe is block. Which can be sucked clean with wet/dry vacuum cleaner. The drain pipe behind the unit is not sloping downward away from the unit. Or the coils of the internal could be iced up. If this is the case the unit should be switched of until the ice is completely melted and switch the unit on again. If the copper pipes leaving the the condenser unit outside is starting to freeze up, the unit is short of gas. Call a A/C company to refill the gas and search for possible gas leaks.
Jan 26, 2010 | Heating & Cooling
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Too much water coming out of the pan (in the front of the ice maker) and copper pipes on top left side are covered with ice.
Not real sure just what you are saying as to what pan? The copper pipes that go to the evap plates where the ice is made are supposed to frost over. They get colder than dew point of the air so this is normal. But all the pipes should frost. Does the unit shut down and give any type of beeping noises? This would be the control giving you a trouble code. You may have a water valve leaking. Turn unit off and see if water continues to run. All water should stop within a few seconds. Let me know what you find. Please verify model and serial numbers.
Aug 13, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Seems to be working but not cooling the house very fast. There is a build up of ice on the unit's copper pipes from the unit to the that usual and how can I get it to function properly?
shut down the cooling. the system should not ice up. The system needs either ref : low charge or a clean filter lack of air flow. The unit must be defrosted prior to any attempt to charge or clean the system. You can just run the blower in the fan on position to defrost the unit.
Aug 13, 2009 | Heating & Cooling
Burning smell and icing
Sounds like your blower motor in your furnace or air handler has burned up. shut the unit down and replace the motor. make sure the ice is melted and the unit is dry before you turn it back on.
Jul 17, 2009 | Sharp CV-P09FX Air Conditioner
Makeing it colder
you need to shut the unit off and let the ice melt completely. after the ice melts you can start the unit back up
Jul 04, 2009 | Ruud UBHC Air Conditioner
Hardly blows cold air
use a heat gun to melt the iced pipes before using it again. have your aircon's thermostat checked/replaced. the thermostat's supposed to stop the compressor at a certain temp. which is before it freezes the pipes
May 20, 2009 | Weather King 10AJA6001AH Air Conditioner
Samsung window air conditioner model aw05ncm7 icing up not cooling
After I opened the front of the unit and discovered it full of ice, I left the unit off until it defrosted, so to speak, after the ice had melted, I turned the unit back on to see what happened. It is working fine now, I'm not sure why it iced up, if this is normal or not, but after it melted the problem was solved.
Jul 22, 2008 | Heating & Cooling
Water leaking onto the floor
You have a condensate line plugged up. So when the defrost cycle melts the ice from the freezer coil, it drains down to the condensate pan underneath the fridge via a tube (frozen pipe). Find the pan underneath the fridge, get the pipe that ends up at the pan and blow air through it. compressed air works the best, but lung power has worked for me in the past. After the clog is passed, there should be no back pressure. If the air doesn't work. You may have an ice blockage. You can try looking for the block, or turn the unit off, and then blow air after the ice has melted.
Nov 13, 2007 | Whirlpool ED5VHGXM Side by Side...
Goodman CLJ30AR32 Air Conditioner Logo
153 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
