Question about IBM eserver xSeries 220 8646
Ram not recognized
I tried adding 2 - 512 mb of kingston RAM of matching spec to the server and it doesnt recognize it. Is it a configuration issue?
  • Anonymous Dec 01, 2008
    I have the same problem. The memory isn't faulty!
    Sergeant:
    Champion:
  • 417 Answers
Should already detect it i guess you got faulty ram take it back get money back
Posted on Jul 17, 2008
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
I replaced a 250 RAM slot with a 1GB RAM slot. There is no difference in speed. Ran a Norton system check and it is still recognizing the 250 mb RAM instead of the 1GB RAM.
try resetting the computer, if that doesn't work it could be that your computer only recognizes 250mb or your BIOS needs to be configured.
Aug 10, 2010 | Electronics - Others
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Wont read memory
The memory might be correct, but the server may require matching RAM. Check your hardware specs for details, but you may need two matching modules in the correct banks for the server to recognize and utilize the RAM.
Dec 16, 2009 | HP Compaq ProLiant ML310 Server
ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
If you would like to verify, here is a link to the manual for your MB:
P5VD2-MX SE Manual
See page viii.
Thanks for using Fixya.
Wayne
Sep 09, 2009 | ASUS P5VD2-MX SE Motherboard
Sony RAM upgrade issues.
sounds like the ram isn't the same. check that. It has to be the same.
Jul 01, 2009 | Computers & Internet
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Dec 18, 2008 | Dell PowerEdge 1600SC Server
Ram
You could try the Kingston Memory Configurator.
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Oct 09, 2008 | Intel (SR1400SYSNA) Server
Ram
Check the configuration of your system, it probably supports 128 MB of RAM at max.
Jul 16, 2008 | Compaq Presario 5000 PC Desktop
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
IBM eserver xSeries 220 8646 Logo
123 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
