My Kenmore Elite has an error code of F then the number 51. I would like to know what this means. Can you help? It is a Kenmore Elite, Canyon Capacity. Quiet Pak 9, Oasis HE Energy Star, will this help?
  • 1 more comment
  • Anonymous May 01, 2009
    i have code f 51 and found that the rotor position switch is updated i must replace drum,and harness also is this a comen problem?
  • Anonymous Mar 18, 2014
    Energy monitor supplied by queensland government climate smart.com
  • Anonymous Mar 25, 2014
    My Kenmore elite gentlewash canyon capacity, quiet pack 9 will not spin fast enough. What should I check to try to fix it?
  • 246 Answers
F51 error code is beacause the computer board did not receive input from the motor on the bottom. Unplug the washer, pull the machine forward and tilt the machine back. On the bottom you will see a large white wheel with a silver allen screw in the middle I think it is a 6mm allen wrech that takes it off. Once you remove the screw and drop the white wheel, there will be a large coil of wires with 4 5/16 screws holding it on, remove these screws and drop the coils. On the right hand side you will see a connector with three wires , unplug it. Use sand paper or a scraping tool to clean all 3 male sides of the connectors. Reverse process to re-assemble.
Posted on Jul 11, 2008
I have frensh door kenmore elite fridge model number 795.72053.110 display error code if someone cane please help me ? ER F5 WHATS THE MEAN .... THANK YOU SO MUCH
faulty cercit board is what you have there sorry to say but it dose happen every so often get in touch with the poeple who you got it off and have the engineer look at it
Jan 22, 2015 | Kenmore Refrigerators
Kenmore elite f 51 code
Error Code
  • Clear the error code and stop the beeping by pressing the "Stop" and "Start" buttons at the same time. Unplug your washer so you can examine the problem.
Function
  • The error code displays because something is wrong with the motor sensor. This can be for a number of reasons. After you clear the code, try washing clothes again and seeing if the error appears. If it does, then you need to take further steps.
  • Sponsored Links
Prevention/Solution
  • Check around the inner washer and underneath for any lost clothes or jammed objects. This can be anything from toys to shoes.
Considerations
  • If there are no objects, your washer parts may need to be cleaned or replaced. Call Kenmore at 800-4-MY-Home to talk to a service representative and find out about replacement parts.
Types
  • Along with "F51", error codes "F1" and "F50" could mean the same thing. Check for these error codes and follow the same procedure with your washer.
Read more: http://www.ehow.com/facts_7565280_kenmore-elite-error-code-f51.html#ixzz346p9Y6ro
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Kenmore Elite top loading washing machine that gives me the error code F51 incessantly. Any idea what this means?
The F-51 error code on this washer indicates that the machine control board in the console detects a motor RPS (Rotor Position Sensor -- tachometer) failure. This can be caused by a number of different problems. You could have a bad RPS sensor, a failed motor, a wire harness connection problem or an item stuck between the spin basket and the outer tub that is interfering with spin basket rotation. A water filling problem could also cause this code to be displayed since the basket would have excessive friction if water is not entering the machine properly. With the washer off, spin the basket to see if it rotates freely. If you detect resistance or suspect that an item is stuck between the basket and the outer tub, you will likely need to remove the basket and check this area.
Oct 18, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Calypso top loader and error code ce
Com error between control and motor. See page 51. Check for corrosion on the pins at the quick connect. Check for broken wires
Sep 16, 2011 | Kenmore Elite HE4 Electric Dryer
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Was getting the f 51 code, now d 5 code. its a kenmore elite oasis canyon top load washer.
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
KENMORE ELITE CALYPSO
Call Kenmore if you bought it new they may have a record of your serial number and be able to tell you what the error message means and if you need a service call to fix or you can do it yourself. my serial number is on the back of the washer on a sticker or a typed silver tag that is attached to the washer.
Oct 03, 2017 | Washing Machines
KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | Kenmore 67082 Electric Dryer
Washing Machines Logo
401 people viewed this question
Top Washing Machines Experts
