Question about Kitchen Ranges
Need to set clock on simpson la stella - Kitchen Ranges
  • Anonymous Nov 01, 2008
    I also can not work out how to change the clock... used to be only 6 minutes fast now it is an hour and six minutes fast... Help would be appreciated!
I have lost instructions and need to set the display (clock) as it was turned off
accidently
Posted on Oct 12, 2008
How do I remove the door on a simpson la stella wall oven to make cleaning easier
go to your authorized service agent and ask for a parts diagram for the door hinges
that will show small locks that when the door is open can be rotated into the slots of the hinges and lock the hinges open
from there you lift the door up and out of the hinge slots
Jun 08, 2017 | Ovens
Simpson Model la Stella Oven Thermowave not working Fan works and other settings OK
Burnt out element , thermostat or switch, test with meter.
Nov 10, 2016 | Ovens
How to change the date on a fossil stella watch
For the single dial (winding crown). Pull out one click and this will change the date, pull out another click to change the time and keep winding forward or backward to get change the day and 24hour clock.
Feb 02, 2012 | Fossil Stella Topring Watch
How do i reset the time clock on a simpson evolution 912
Can you add a full model number? I am having trouble finding the manual from the information given. From other oven manuals from simpson, it sounds like the clock is programmable when power is first supplied, so unplug the unit, wait a few minutes, and plug it back in. Then press the - and + buttons to set the time. 5 seconds after the last change the time will be set.
Oct 03, 2010 | Ovens
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
How do you set the clock manually?
honest advice ,ask one of the grandkids because if not you will need a degree in advanced electronics ,remember the simpsons episode ??to set the clock on the video
Jan 06, 2010 | Panasonic DMR-E85H DVD Recorder
Can not set clock on Simpson La Stella oven
How do i set the time on a Simpson La Scala wal oven
Jun 30, 2009 | Electrolux Ovens
Simpson Atlas Apollo ceramic top stove, Digital clock etc. Just installed. No user guide to set clock etc. Oven wont work, suspect clock needs setting. Can I get a user guide?
Hello, I think I have the same oven as you, and yes the oven doesn't seem to work unless the clock has been set.
On my oven, there are 4 buttons and a dial below the digital clock.
To set the clock, you need to turn the dial whilst holding any two of the 4 buttons down.
For me it's a two handed job.
Cheers,
Michael
Nov 30, 2008 | Kitchen Ranges
Soundesign 316G Jukebox Alarm Clock-can't set alarm
Press the alarm reset ( on/off ) for a few seconds.
Same as you do to set the time
Feb 13, 2008 | Novelty Simpson Jukebox Alarm Clock Radio...
Kitchen Ranges Logo
483 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
