Question about Casio Exilim EX-S500 Digital Camera
Lens problem i was at this party and i let my friend hold my camera and he dropped it and the lens is sorta bent and now it wont close and i got it in NC can i fix it myself!?
  • 190 Answers
Dear Customer,
When you say the lens barrel is bent, do you mean that the camera won't turn on ?, or the lens barrel is just bent and it looks outlandish. However if it's not turning on follow these steps:
1) Try to gently re-position the barrel, and make it more stortionate.
2) try to recharge ( or get new batteries ), and see if the lens will withdraw.
Unfornately, when you drop a camera, many warranties are voided, and you have to pay to have it fixed, but i doubt it would be that much money to fix.
Please rate this solution.. Thank You..
Posted on Jul 11, 2008
I dropped my slr camera and now the lens wont attach back on
Most likely. If the lens is from a major camera manufacturer, take it to an authorized repair shop and they can replace the mount. If it's a third-party lens then it may be more difficult.
If you want to do the replacement yourself, you may be able to find the appropriate part here. Since you declined to specify the make and model of the lens I'm afraid I can't tell you whether they have it or not, so you'll have to look yourself.
Jun 04, 2012 | Cameras
It dropped on the floor and it's lens are bent so it wont come in or out but i can still turn the camera on but it says system error
The problem is more complicated to resolve at home.Ask a friend skilled in electronics or go to service center (too expensive)
Sep 30, 2010 | Sanyo Xacti VPC-S60 Digital Camera
I dropped my Polaroid i532 and now the lens wont
You must get your cam serviced... due to **** your motor (which operates lens movement has stop working. or the lens has bent and therefore stucking..... taping lightly near the lens may help you... The common reason for motor not working is loss of power connection....
Hope this has helped you..
Please rate the answer...
Jul 07, 2010 | Polaroid i532 Digital Camera
The lens cover does not open all the way. I have to use my fingernail to do it.
It is either bent or has grit and dirt in between the slides. Try using canned compressed air, such as you use to clean a computer keyboard with, to blow air between the slides. If that does not work, even though you will have to be very careful, while the lens cover is closed put a single drop of WD40 on the cover and spread it with a Qtip over the entire cover surface. Holding the camera, front facing down, try turning it on and off several times. If that frees the lens cover, turn the camera off and wipe the surface of the closed lens cover with a soft tissue to clean the WD40 from the surface. Make sure then that your lens is clean before using the camera. If the lens cover is bent, then none of this will work.
Mar 24, 2010 | Nikon Coolpix 775 Digital Camera
The lens want close due to being bent
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 09, 2010 | Sanyo VPC-E760 Digital Camera
Dropped camera now lens wont close. It says lens
Remove the batteries and insert new batteries . Sometimes this may work but in your case the lens is stuck inside, or it will have been damaged . Nothing can be done other than taking to service center to get it repaired .
Hope this helps .
Dec 16, 2009 | Canon Cameras
My olympus fe-370 lens wont close??
the simple thing you can do is take the camera to the nearest service center and get the lens array replaced. it would cost around 60$. remember never drop the camera down to the floor. that too in switched on condition. that has made the problem in your camera.thanks for contacting fixya!
May 31, 2009 | Olympus FE-370 Digital Camera
The lens wont close and it keeps saying on screen "lens error restat camera" but when i turn it back on it doesnt do anything
Your lens frame - that which moves out when the camera opens is probable bent. Looking down at it from the top and sides, does it look bent? By grasping is firmly but not hard try softly to bend the lens frame in the opposite direction, carefully.
Feb 19, 2009 | Canon PowerShot A430 Digital Camera
My Z1275 was off with the lens open. When I turned it on, the lens moved a little, the screen came on
for an instant, and then the camera off.
Here is what I did to "fix" it.
I turned it on and helped the lens (gently) close while it was moving. It closed and the camera came on.
It must have been dropped and slightly bent in such a way where the lens could not close.
Good Luck!
Dec 29, 2008 | Kodak EasyShare Z1275 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
134 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
