Question about Roper RES7646KQ Electric Dryer
Roper elec dryer
This dryer makes a sound like it wants to start but i have to open the door reach in and hand turn the tub then close the door real fast and start it. I'm kinda of giving it a jump start.
  • 525 Answers
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance.
Clicking on the underlined links will take you directly to that page.
Very rarely, a voltage issue could cause this symptom, but you should rule out the other possibilities first, unless you have a volt-ohm meter, then a quick check of the voltage MAY rule out these other issues.
This could be a motor or drive system issue. To test for a motor problem, you will need to remove the drum belt. See exploded view diagram link below, for disassembly.
http://www.repairclinic.com/0100_16.asp
If the motor fails to start, replace the motor, See link below.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2584&PPStack=1
If the motor starts, then you will have to look for:
1. Blower obstruction
2. Rear drum rollers.
3. Idler pulley
4. Drum belt, See link below
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=587636&PPStack=1
5. Front tub glide bearing and seal assembly. See link below.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2702&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 11, 2008
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
My Roper dryer has power I can here it, but it does not spin the clothes dry...doesn't turn on. How do I figure out what is wrong?
try this,open the door,with one hand push in the door switch,with the other hand spin the drum,have someone else push the start button,if it runs you have a bad motor
Feb 22, 2011 | Roper REX3614KW Electric Dryer
My Roper dryer heats up but does not turn when I push the start button. What would cause the dryer to not spin?
one is the belt may be broken or have slipped off the pulley.the door switch could also be bad. try and hold the door open and depress the door switch at the same time someone is pushing/turning the start button and then try to rotate the drum be hand and see if it will turn. the motor could have alot of lint build up and cause the motor not to turn.
Oct 13, 2010 | Roper REX4634KQ Electric Dryer
Dryer won't start. has power, lights are on, when I push start I just get a loud humming sound.
Try to turn the tub by hand, if it will not move or is real hard to turn, your motor may be locked down. They usually make a humming sound when you try to start.
Aug 28, 2010 | GE DPSB513BW Dryer
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
Dryer won't start
Try 2 things to see what has happened.
1st listen for a click from the door switch just as the door opens or closes. (No click = no start)
2nd reach in and rotate the drum by hand just a little bit making sure you hear the motor also turn. Then try to restart the dryer.
If rotating the drum enabled you to start the dryer the motor switch is sticking.
Kelly
Feb 25, 2010 | Dryers
Roper dryer by maytag press star button here noise but does not start?
you will nead someone to help you to see if you have a bad moter.first open door,with your right hand push in on the door switch.hold the switch in ,have someone push the start switch in and at the same time with your left hand turn the dryer drum clock wise,if the dryer starts than you have a bad moter.the cost of the moter would be 1/3off the cost off a new unit.
Nov 20, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Fridgadare gallery electric dryer
i need the model number on this one some of those galleries were double rotation some wernt now if you hit the start switch and hear an electric buzzing sound open the door hold the door switch with one hand and spin the tub real hard to the right with the other but be ready to jerk your hand back if the motor starts then change the motor or clean the centrifugal switch most of time have to chang the motor when you find out reply to me for detailed instructions on how to do it also the rear tub bearings are bad about going out and jamming the motor 6 years old is about the time so check the tub for rotation first and if you have to do the spin start test be sure to set the timer first ok
Jan 02, 2008 | Dryers
Roper RES7646KQ Electric Dryer Logo
202 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
