Question about RCA R52WM24 52" HDTV Projection Television
No picture when the power button is green
When I hit the power button it glows green and the screen is black. The power button goes off and back on while the screen is still black. It does this like 3 times and then just stays off
  • slotman380 Dec 02, 2008
    Power button is flashing no and off and no picture as screen is black. The chassis number is ITC222A.
  • RCA Master
  • 8,617 Answers
Can you look on the rear panel and post the Chassis number to your set as that model has used 3 different chassis designs. They have a ITC222, ICC222 or a ATC series. If you can respond to this same post with the chassis number I will be able to assist you with the problem
Posted on Jul 11, 2008
Get a black screen when turned on
Same thing happened to me. Unfortuanatley, I had to get a whole new phone because it was a "manufacturer defect"
Jul 05, 2015 | Televison & Video
HP Pavillion screen goes black when inactive for short time. Even when I fixed all of the power settings to never shut off or go into sleep mode. If I don't use it for 30 seconds then the screen...
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 08, 2012 | Computers & Internet
Shows picture for a second when i press button than goes dark
Issues with back light:
Please do not attempt to diagnose if no competent.
Do at your own risk.
Check for 24 Volts power to the inverter board
No Power---Check Power Supply
Power Present---
Verify status voltage 3v to 5v on inverter board harness (plug)
Replace Inverter Board
Feb 11, 2010 | Tatung V30DMTT 29.6 in. LCD Television
Screen goes black with green power light flashing. Then screen comes back on and 30 sec later repeats
after unplugging for 24 hours and hitting reset button. look at the replacement of the DM board capacitors.
Jan 26, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
RCA R52WM24 52" HDTV Projection Television Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
