Question about Refrigerators
In Maytag MFD2561HES, freezer works but fridge is not cooling.
  • hasenyager Sep 30, 2008
    Freezer is zero degrees, refer is 80.  What gives?
How do I defrost the freezer only
Posted on Jul 24, 2009
My Maytag Refrigerator is not Cooling enough. My Freezer works fine and we have unplugged and let everything defrost and plugged back in but still not working properly. Model # is MFD2561HES
Its possible the evaporator fan is bad. Air is drawn from freezer to cool the refrigerator side and ultimately controlled by the fridge side thermostat. Or... Low freon.
Oct 28, 2013 | Maytag Refrigerators
I have a Maytag fridge MTF2193arw, the freezer is nice and cold with the fan working, but the fridge is not cold with no air movement.The unit is 3yr
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Maytag Refrigerators
Have a MFD2561HES refrigerator and both the
i would call who ever replaced your compressor usually they warrant their work for maybe 3 months or so he might have had a bad weld he made when joining tubes,,, it is worth a shot
Jan 31, 2010 | Maytag Refrigerators
MFD2561HES The fridge temperature wants to fall to from set temp 40 to 32. I set it higher and it climbs back up in time but will lower itself back down in a day or two. Why would it continue to cool...
The control board in the control panel should be regulating the air damper correctly. If the control board is responding this way the the damper is told to open too wide allowing colder temperatures into the fresh food section. The thermistor also may not be working properly or may and the board could be the total problem. This is going to be something that an Authorized Maytag Technician will need to have a look over. Switching the Control Board Part number W10207861 Temperature Control Board and 12002356 Thermistor just may solve this. Sea Breeze
Oct 23, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HES Reefer not cooling
hello frooska,
kindly look at the back panel of the freezer section. if you can hear the humming sound, find out where it is coming from. if the sound is coming from the compressor, that means the evaporator fan is not running.
but, take note that u need to press the door switch of the freezer in order to check the fan. the fan stops every time the door is open. if the fan is not running, you have to remove the middle panel, above the evaporator, the fan would be there. ( in the freezer section)
but if the fan is running and the back panel of the freezer is full of frost, then that would be a defrost issue.
defrost heater, bi-metal or defrost controller.
Tnx 4 uisng Fixya,
Drcool
Dec 16, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
