Question about JVC AV-32FA44 32" TV
TV made a loud pop
My JVC made a loud pop after i turned it on. I unplugged it and plugged it back in and it will come on for a second and then shut off again. The green light in the front flashes but nothing else happens. Do you have any idea of what the problem might be? Thank you.
  • 417 Answers
sounds like a popped power capacitor, its going to have to go to the shop most likely around 100.00 repair. taking the back off yearly and airdusting them helps, especially if you have a smoker in the house. caution high voltage present even when off, the heavy single red wire going to the tube is high voltage be careful.
J
Posted on Jul 11, 2008
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Sleep timer will not shut off We can not turn it on to shut it off.
unplug for a quite few hours, press and hold power button for 5 full seconds while it is shut off, then wait half hour more and plug back in and it should reset itself.
Jan 22, 2010 | JVC AV-27D203 27" TV
Loud Pop now it wont turn on.
the tv power supply might have failed. there are also two power boards ,x and y. this is an involved repair. better to have a repair man check it out
Jul 09, 2009 | V, Inc. Vizio P50HD Plasma Television
Turns on the shuts off
I had the same exact problem!!!! If you unplug it, then plug it back in after a couple of days. You will hear a frying sound then a loud clap!!!! Solution: Replace it with a LCD.... Not worth getting fixed!!!
May 26, 2009 | Emerson DTE315 TV
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Loud possible fan noise
if you are not afraid to get in to the back of tv, the chassie has 4 different fans,you can unplug the tv remove all of the screws on the back,and remove the lamp door,there are about 5 plugs on the top of the chassie that plugs in the tv,donot unplug these plugs ,you can pull the chassie out of tv until you run out of wire on the plugs,then plug the tv in,turn the tv on, and you might hear the fan thats bad. If you are not comfortable with this call a repair man,the fans are not that expensive,and are pretty easy to change.i can guide you thru the replacement process if you need my help.
Jan 08, 2008 | JVC LT-37X776 37 in. LCD HDTV
No picture but sound is perfect
Sounds like the video output has a problem. Maybe missing the 200 volts from the High voltage transformer. The vertical circuit may have an issue. Either way it's hard to diagnose without looking at it. If you need a technician contact JVC online at: http://maps.jvc.com/cAscList/ Good Luck
Apr 29, 2007 | JVC AV-36FA44 36" TV
JVC AV-32FA44 32" TV Logo
149 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
