Question about Dryers
Gas dryer does not heat at all
Whirlpool ultimate care II LGQ9857LW0>
Before complete loss of heat one day, the week before it did not heat up one time, but then was ok>
i replaced ignitor, but did not fix. Tried various timer and temerature settings to no avail.
Other ideas please>
Jeff
  • 5,911 Answers
Does the dryer try to ignite? That is, does the igniter glow? If the igniter is glowing, and you have already replaced it, you may have a problem with one or both of the gas safety coils. There are two of them on your dryer burner assembly. One is the main coil (two terminal) and one is for the pilot position (3 terminal). When they go bad, the gas valve will not open. The result is an igniter that glows, but there will be no gas flow or ignition. It is recommended that you replace both coils at the same time.
You can find your parts at searspartsdirect.com by typing in your model number and looking under the "Burner Assembly" heading on the next page. The coils are listed as item numbers 13 & 14 (part numbers 694540 and 694539, respectively). You can find these same parts at repairclinic.com sold as a set for a lot less (item #3479) - a savings of about $50! I mention the Sears website, because it offers great part illustration diagrams. If I'm not accurate in the description of your symptoms, please post back and let me know. I hope this helps you.
Posted on Jul 11, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Whirlpool AccuDry Ultimate Care II Dryer will heat up
    Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
    heatman101
    Jul 17, 2011 | Dryers
    My gas dryer has no heat
    long dry times are a venting problem. if no heat at all it could be your ignitor, a thermal fuse, or the secondary gas coils, all are replaceable and reasanoblyy cheap between 30-90 dollars usually so its up to u it u want to repair it.. if long dry times i would unplug the venting from the rear and dry a load if it heats faster than u know ur venting is clogged and u might wanna clean ur ducting and replace that venting tube. also u can go outside while running and see or feel if air is being pushed out while its running hope this helps let me know how it goes
    Feb 22, 2010 | Whirlpool LGB6300 Gas Dryer
    We have a Whirlpool Ultimate Care II gas Dryer that is getting intermittant heat. Sometimes it will heat, sometimes it won't. Iin addition, today it stopped rotating as well. Ideas?
    Could just be a matter of wires coming loose. The movement and vibration of the spinning could have shaken wires loose. look for any wires not connected to anything.
    Nov 06, 2009 | Whirlpool GGQ8831L Gas Dryer
    Whirlpool ultimate care II dryer will not dry clothes
    does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
    Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Ultimate care II Whirlpool dryer
    yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
    May 24, 2008 | Dryers
    Whirlpool Gold Ultimate Care II: No heat
    didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Dryers Logo
    176 people viewed this question
    Top Dryers Experts
