Question about Hotpoint RVM1635 Microwave Oven
Microwave power level
Power level button doesn't work. says cannot be changed at this time. microwave doesn't heat food.
  • Anonymous Mar 14, 2014
    microwave has power but no heat for food or drink
  • Anonymous Mar 15, 2014
    i just installed a caso microwave, and now it is not function. I can not warm up food. i did adjust the power to 80 or 90 . but it is still not working, i did reset the time also. could you help me out
  • Hotpoint Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can download it free from GE/Hotpoint.
Please reply back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 11, 2008
Temperature at 10 power level
It does not work that way. The microwave OVEN generates (electromagnetic) microwaves that are absorbed by the molecules of the food in the oven, the container and the air.
The absorption rate depends on the molecular composition. After enough microwave energy is absorbed the overall temperature increases and the food is warmed, heated or cooked. If your mixture is inhomogeneous some parts absorb more energy while other absorb less and you can have hot spots.
The power level by itself won't give you an indication of the temperature because you need to know the time that the power has been applied. In simple terms Energy =time*power. The temperature reached is somewhat proportional to the energy, that makes it dependent on the time and the power.
Dec 22, 2013 | Haier MWM0925T 0.9 cu. ft. Microwave With...
Temperature in degree centigrade at 10 power level
Everything works fine, except my food is still cold
Check the "power" level setting.
Most microwaves allow adjusting the power level from 1 to 10 (or 10 to 100 on some models). 10 (or 100) is the highest/quickest setting.
I can check mine by entering a time...then before pushing "start"....push the "power" button....and change the level if I want.
Mar 23, 2013 | Microwave Ovens
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
Microwave oven is not heating food power level can;t be changed at this time
That shows triac semiconductor is working fine, the problem is the magnetron, "heats food" cracked high voltage diode or a shorted high voltage capacitor.
Mar 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
MY MICROWAVE IS NOT HEATING
If the microwave is turned on and you can hear the fan working when you set the time you should make sure of those things:1. You have selected the proper programme. Some microwaves have a control desiged to use the programs on the buttons. if you want to you the buttons to set time you should select "microwave" or a similar button and then press the power level like "1", "2" or "80", "100" (being percentage) and then press the buttons for timing.2. If you have used it for a while and it suddenly stopped heating the food, than it could be that your magnetron (a spare part) has burned out. Have a specialist replace it, or just get a new microwave, the price difference won't be that great for standard issue microwaves.
Feb 25, 2012 | Whirlpool Microwave Ovens
My GE Microwave Oven won't let me change the Power Level. It is on 10 and takes forever to warm up food. It is supposed to default to Hi but doesn't. I followed the directions for changing the...
There is a solid state switching device called a triac "electronic voltage controller" that has malfunctioned, it controls the power level settings when making power selection, It will need to be replaced to correct the problem. This repair should be done by a qualified technician because dangerous high voltages are present.
Jun 07, 2011 | Microwave Ovens
How doI change the power on my microwave?
  • Press "Time Cook" or "Micro Cook."
  • Enter cooking time.
  • Press "Power Level".
  • Select a desired power level 1-10 (default is 10).
  • Press "Start"
Jul 06, 2009 | GE JES1855 Microwave Oven
Hotpoint RVM1635 Microwave Oven Logo
717 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
