Question about Systemax Computers & Internet
Computer restarts by itself continuously and does not boot up completely
I have a Systemax Laptop (SYS8089P). It suddenly shutdown while I was watching a video on www.youtube.com Ever since then, the computer is unable to boot up. I cannot even select the safe mode or enter setup screen. The computer starts when the Power key is pressed, but restarts again after displaying the windows screen for a few seconds. I want to restore computer to factory settings, but I do not know the short-cut keys. This is a refurbished laptop, so I do no have teh Microsoft XP CD or any manual. Please advise. Thank you very much in advance.
Regards,
Kim
  • 80 Answers
Hi im wesley. ok to restore to factory settings go to your bios witch is when you boot up and press delete to enter setup thwn at the bottom of the screen it will say like F5 for default settings press that button and it will reset if it doesnt work open the computer up and take the power out and take the battery out for bout 10 minutes and then place it back in along with the power and it will reset. you might have to format your hard drive because it might be a virus that keeps rebooting your computer i had the same problem once.
Posted on Jul 11, 2008
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
My pc will restart itself ..... but when i play games it wont restart ...i already turn off auto restart.... change the power supply to 500watts... but when i surf the net it will restart suddenly but...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 05, 2011 | Computers & Internet
My computer says the last attempt to restart the system from its previous location failed. Attempt to restart again? Delete restoration data and proceed to system boot menu or Continue with system...
Looks like the OS is corrupt. You may want to try doing a repair reinstall using the OS CD. What is the version of windows you are using? (XP, Vista, 7)
Mar 01, 2011 | Systemax Ascent PC Desktop
Continuously rooboot itself?
Hi.
When the laptop keeps rebooting shortly after Windows starts loading the reason is usually because the system files loaded by Windows at startup are corrupted.
Windows cannot complete booting and keeps restarting.
The fastest way to Fix the problem is by reinstalling Windows.
If Windows is installed on the same directory of the existing system performing an upgrade installation, the setup process will preserve all personal files, most installed software and settings.
Before reinstalling Windows you can try starting in safe mode (eg. on XP pressing f8 on startup). If the computer starts in safe mode, go to system restore and perform a restore to a date before the problem occurred. Unfortunately when the computer keeps re-booting ut will hardly start in safe mode. Often reinstalling Windows is the only option available.
Aug 02, 2010 | Acer Computers & Internet
My HP wireless mouse all of a sudden stopped working (usb connection to my laptop.) I did change the batterie. Do you have any idea what is going on?
Try to completely shutdown your computer when you connect it and turn your laptop back on once the pc is already booted back up switch on the mouse...
Mar 19, 2010 | HP Wireless Optical Mouse
My laptop keeps restarting without me touching the same thing
Boot into safe mode, allow it to boot completely. Then shutdown/restart as normal.
It should be back. If not, allow it to reboot and choose the "Last Known..." option and boot from there.
Good luck
-Carlos:
Dec 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
Systemax factory restore - how?
Tap F4 repeatedly to launch the recovery console on SystemMax Machines with the recovery partition still intact. Then you should be able to restore the machine to factory defaults without a CD.
May 05, 2009 | Systemax Venture PC Desktop
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Laptop boots then shuts automatically off
i thinkl you got a virus,, i suggest you to restarted than scan your computer.
Feb 23, 2008 | Toshiba Satellite A85-S107 Notebook
Computers & Internet Logo
266 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
