When attempting to install Print Artist Version 22/ Platinum Edition, I received the following message: Error 2350. FDI Server Error I tried re-installing and received the same message.
  • 3,940 Answers
If you are using Windows XP install
windows installer 3.1
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482fc-5f56-4a38-b838-de776fd4138c&DisplayLang=en
XML Services 6.0
http://www.microsoft.com/downloads/details.aspx?familyid=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
and .NET framework 3.5
http://www.microsoft.com/downloads/details.aspx?FamilyID=333325fd-ae52-4e35-b531-508d977d32a6&DisplayLang=en
Posted on Jul 11, 2008
Error 1935 while trying to install Print Artist 25
Unlimiting the registry size could work:
Here are the steps:
1) Type REGEDIT in run
2) Navigate accurately to:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
3) On the right pane, locate the following
Key: RegistrySizeLimit [Type: REG_DWORD]
4) Double-click on it.
5) On the dialog box, select DECIMAL radio-button
6) Erase the previous and enter the following number:
4294967295
7) Again select, HEXADECIMAL radio-button
8) Click okay and restart computer
9) Everything will be okay, ENJOY! try to install the package again.
gnaveendra@gmail.com
Feb 11, 2014 | Nova Development Print Artist Platinum...
Is Print Artist Platinum Edition version 22 compatible wit Window7?
Print Artist Platinum Edition version 22 is compatible with Win 7.(x86 X64)
You can check this @ Windows 7 Compatibility Center
Hope it helps.
Jun 01, 2011 | Nova Development Print Artist Version 22...
Print artist platinum 22 does not want to install on our new computer with windows 7, is there a patch or some drivers that need to be installed?
Try launching the program in compatibility mode. If this is a disc you're trying to install from, click on Start, goto Computer, go into your DVD Drive, right-click the Setup's EXE file, then Troubleshoot Compatibility.
If this is just a Setup EXE file you are trying to load on your computer you can do the same. Just right-click and select Troubleshoot Compatibility.
When you're presented with a list of options, select "This program worked in an earlier version of Windows", then hit Next. Just follow the prompts and then try installing it again.
Feb 23, 2011 | Nova Development Print Artist Version 22...
Every time I try to boot up print artist platinum edition it says Print Artist Platinum has encountered a problem and needs to close. What do I need to do to fix the problem?
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
Jun 29, 2010 | Nova Development Print Artist Version 22...
Error 2350
THE PROBLEM The Windows Error 2350 occurs when the installed version of the Windows Installer is too old for the MSI to execute. The registration entry for the engine has been damaged and all attempts to execute the MSI installation packages will not be successful.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
THE SOLUTIONTo fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver (Type both command in run) or the command line switches. The user will then have to restart Windows.
Feb 12, 2010 | Microsoft Windows Vista Home Premium with...
Error while installing/ error 1305/reading from file c:\Program Files (x86)\Nova Development\Print Artist Platinum\Layouts\Postcards \GeGeneral Greetings\990Ball & Chain (8386).ppc.lyt. Verify that the...
error's like this are very common and most of the time are caused by microsoft windows updates,go to the site and check first for any updates that need upgrading that don't automaticly update and see what results come up? then you can try and do your install,good luck,garnedd.
Sep 12, 2009 | Nova Development Print Artist Version 22...
Boot Up error message
I have the same problem. I emailed Nova support and the first reply had a link to Dotnetfx3.0. He said install that and it would fix the problem. I'm running Vista and I discovered after trying to install this version of Dotnet framework, that 3.0 is already integrated into Vista. They should have known that because I told them what platform I was using in my original support request. The next suggestion was to install dotnetfx3.5 which I did along with it's service pack to no avail!! I really don't think their support staff is too computer savy! Their last response when I told them that didn't work either was pretty much "sorry". Anyway, I haven't given up and am concentrating on the dotnet connection. I'll post here if I happen upon a solution.
Jun 15, 2008 | Nova Development Print Artist Version 22...
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
