If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Y-Sustan board should be suspected. If you wish to get more details, check this
site. Pull up older posts there. Check the site with patience, as it has over
2300 posts now. All are related to
electronic equipment repair help.
Search the site by 'Timeslide' option.
It will make search easy. Or,
type in the brand name to your device into its search box, and press "Enter" Fault to Plasma displays are described in detail with screen shots.
I have a 51" magnavox plasma. after about one half hour the bottom half of the picture goes black, and u can still see the top half of the picture. what can that be
Replace the scan drive board also called X-sustain board. This is the board on the upper left side in the back of the set with a huge heat sink on it. you can find them online for about 175.00. The p/n is pkg50c2g1. Be carefull with the 4 ribbon connectors that go to the display.
