Question about Toshiba Satellite A105 Notebook
Toshiba satellite a105-s4004 power problem
My wife has a Toshiba Satellite A105-S4004. It will not power up. I have checked the power adapter and it does measure 15 V. The light around the power up button does not light up with or without either the battery or power adapter plugged in. When the battery is in and the power up button is pushed the small yellow battery light on the front of the computer blinks a few times but then nothing happens. Could it be the power jack or something else? How do I check the power jack? How do I get access to the power jack to check it? I need to know in a hurry.
  • caddokid Jul 12, 2008
    Thanks for trying. I had it checked and it turned out that the power adapter was providng a fluctuating voltage under load and the motherboard was out.
  • ktznrbtz Jul 22, 2008
    Yes, I Have the same problem. I would like to know if the computer
    should work without the battery installed? The reason I ask it that I
    think it could be the battery that is the problem? When I remove the
    battery the unit won't power up either with or without the battery,
    that's why i am wondering if it is designed only to work only when the
    battery is installed? I am thinking that if it is the battery the unit
    should work without it in the computer? Any help and or advice would be
    much appreciated. Thanks in advance.
    TomCat
  • 2,427 Answers
It sint the power jack, but rather the Power control circuit. This circuit isnt repaired but replaced. I recommend taking this to an authorised service center or a certified technician of the latter is not easily avilable. If you choose to repair this at your own risk please remember doing so without the necessary knowledge will result in major damages.
Posted on Jul 11, 2008
2 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: Toshiba Satellite A105-S4004 memory slot not
If this is a new module, make sure the specs are the same as the old module. If it is an old module then it is more likely the module has over-heated and died. Try swapping the modules with the different slots and make sure they are seated all the way in the slots. Afetr each time, check the ram in the BIOS settings to see if the BIOS sees the ram installed and not just the Windows system utility. That way we can figure out whether it is hardware or software. If the bios sees the ram and windows does not, then the hardware is fine and it is an operating system problem. If bios does not see the ram then it is hardware....either the stick is bad, the slot has failed or is disables, or it is not properly seated and is not getting good contact. Try cleaning the ram contacts with a Q-tip and alchohol, dry completely, then reseat.
Posted on Oct 29, 2009
I have a Toshiba Satellite A105 laptop that will not power up.
Get sure the memories are good. then try reseting the BIOS by removing the BIOS batery, let it out for 5 minutes and place it again. Though you have to disassembly almost the whole laptop. If dont, chek the other "pheripheral" devices, HDD, DVD, and another (If)
Apr 20, 2010 | Toshiba Satellite A105-S4004 Notebook
How can I restore a toshiba to factory reset with out the recover disc the man that own it died and hes wife can't use it we don't know his pass words satellite a105-s4004
if its a log in password, you can get around it. when the conputer starts and goes to the log in screen, log in as administrator. go to start-control panel-user accounts-user accounts, then click on his account and remove password. maybe that will help you guys
Apr 14, 2010 | Toshiba Satellite A105 Notebook
MI NIETA TOCO EL TECLADO Y LA IMAGEN ESTA VOLTEADA
Trata esto:
Ctrl + Shift + R
Aguanta la llaves Ctrl-Alt
empuje up arrow (Flecha arriba)
Nov 29, 2009 | Toshiba Satellite A105-S4004 Notebook
I have a Toshiba Satellite A105-S4004 and one of the memory slots seems to not be working/doesn't recognize a memory module. It's the correct module for it.
There could be several problems to cause this. I would like to start out by giving you some somple steps. If the Ram you are trying to install is larger than the first ram, then place the larger one in the first slot or slot A. Some computers are very finicky when it comes to this. 2. swap new memory module with existing module and see if it is recognized then. If not then your module is bad.
Oct 29, 2009 | Toshiba Satellite A105-S4004 Notebook
TOSHIBA Satellite A105-S4004 doesn't boot
unfortunately older models such as the a105 do not have a recovery partition. however recovery cd's are around 25 dollars if you contact toshiba directly
Oct 27, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
Need a motherboard for Toshiba Satellite A105-S4004
http://www.google.com/products?hl=en&q=Toshiba%20Satellite%20A105-S4004%20Motherboard&um=1&ie=UTF-8&sa=N&tab=wf
Jun 29, 2008 | Toshiba Satellite A105-S4004 Notebook
Display Problem
Try connecting an external monitor if this also shows a "bad" picture then probably the graphics chip on the laptop is faulty.
Mar 14, 2008 | Toshiba Satellite A105-S4004 Notebook
Cracked Screen
The backing of the screen will stay. You'll only be receiving the lcd.
http://www.fonerbooks.com/laptop_4.htm
Mar 08, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satillite A105
Send it back to geek squad and have them correct the issue.
Feb 08, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Notebook Logo
566 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
