Question about Dell Inspiron 8600 Notebook
Dell 8600 Optical drive NEC 5100A problem
The optical drive no longer spins when a disc is inserted & the disc only clunks every 2 or 3 seconds. Then either ejects the tray or promts to insert a disc. A check in devices in the computor control panel tells the device is working ok, but i think otherwise.
Can another optical drive ( possibly different brand) be fitted to this modular type bay.
Is it as easy as unscrewing the Dell slot drive carrier from around the optical drive unit & refitting it?
  • darrenw496 Jul 15, 2008
    Any suggestions what I can replace this NEC ND 5100A optical drive with.
    that will fit into the existing cradle
  • 2,028 Answers
The optical drive is shot. You can put a drive from another machine or brand in the drive carrier as long as it fits. I've had some drives that the face plate is too long to fit, and others where I trimmed the face plate a bit and made it fit.
Posted on Jul 11, 2008
  • Ryan Rogers
    Ryan Rogers Jul 15, 2008
    I would suggest another drive from a Dell. The cut out slot for the release mechanism makes this face plate hard to match. I do know that, besides your model series, the D series latitude, inspiron 2200, and inspiron 6000 series have the same type of drive.
How can I remove the barrier to install a second optical drive
Two things have to be done in order to add a second optical drive.
1. Open case, remove front cover of case.
2. Remove blank from lower optical drive from front of case - remove blank (chassis part) from optical drive space.
The black insert that can be seen, removes from back on this model.
The 'steel' part on the chassis should pop out fairly easily.
Jan 19, 2012 | Dell Inspiron 620 MT Desktop Computer...
My dell m1330 DVD loads the disc and spins but never shows up?
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' on it your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer
Mar 09, 2011 | Dell DVD-rom DVD Drive
Optical Drive stopped working. Gives message: Insert Blank Disc when any disc is inserted, even a blank one. I checked all connections, and configurations. Have 2 of these, settings are the same on...
Sounds as if the drive is either dirty or has just failed.
I would try cleaning it with a cd drive cleaner if that does fix it the drive is bad and needs replacing.
Mar 02, 2011 | Dell Inspiron 560 PC Desktop
My Macbook 3,1 superdrive slot load optical disc drive won't accept CD's of any kind. The disc will physically get all the way in the drive (as in I cannot see any part of it or push it in any further) but...
There is no need to force the disc into the optical drive. You should be able to stick half of the disc into the optical drive and it should see it, grabbing it the rest of the way in.
But it sounds like the optical drive is failing and it will need to be replaced.
Dec 18, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dear FixYa ADDENDUM: 3/6/10  RE: NEC
Try this link below. This will help. Also get ASPI at link below that too can help. have you installed NERO? OR Clone DVD or UltraISO, install those anyway. -
Mar 06, 2010 | Dell Vostro 200 PC Desktop
DVD rom drive not seen on My Computer Page using XP profesional unable to identify drive but drive spins up when inserting a disc, No optical drive on system page either. Notebook had new hard drive after...
4 Possibilities can occur there.
1. It's either that the Optical Drive is disabled in the BIOS
2. It's either that the Optical Drive is faulty
3. It's either that the Optical Drive's connection to the motherboard is loose or disconnected
4. It's probably the Operating System is not showing the drive for some unknown reasons.
This is only based on my experience troubleshooting desktop and laptop computer.
Jan 11, 2010 | HP Compaq nx6110 Notebook
My dell cd writer has stopped reading CD's & will not burn music it just says "insert disc" even when there is a disk in. PC is only about 2 years old
This is unfortunately a fairly common problem with optical drives, from both laptops and desktop pc's. It unfortunately means replacing your writer or if this is too costly you could opt for an external writer which plugs into a USB port.
Best wishes,
Dec 17, 2009 | Dell Dimension E520 PC Desktop
My cd drive will not open or operate
You might have a bad drive,have you tried removing the drive and re-inserting it? You can get replacement drives on ebay or you can also look at they sometimes have them cheap.
Sep 26, 2009 | Dell Latitude D600 Notebook
CD-ROM won't spin up
When the CD drive doesn't detect a disc or can't read a optical disc, it stops spinning. Perhaps you need a new CD drive or Lens needs cleaning.
Sep 09, 2009 | Dell Dimension E310 PC Desktop
Dell Inspiron 8600 Notebook Logo
115 people viewed this question
Alun Cox
