Question about RIM BlackBerry Pearl 8100
My dvd player was dropped and the screen lights up and it says it is reading disc and gives a loading prompt and suddently turns off
    Problem Solver:
  • 22 Answers
Did you get a new battey for it becuase when u droped it the battey got wead or get a new screen for it!
Posted on Jul 11, 2008
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
My Samsung Blu-Ray player P1590 doesnt play regular DVD's. is this normal? Whenever I put a regular DVD it tries to load but it eventually posts a message on my TV screen saying "unable" to...
I have a Samsung BD-P1490. When I turn is on the display reads "Load." It never displays "No Disc", or trys to play a disc if one is present. I have never updated the firm ware. Any ideas?
Jan 20, 2011 | Samsung BD-P1590 Blu-Ray Player
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Portable dvd player won't load disc
well..I ve heard this problem many times..a DVD player says "no disc" or "invalid disc" only if the disc that you have inserted is damaged or else the DVD reading lens has been damaged when you dropped your player..! That maybe the problem..I suggest it is better to show it in some shop ! or to the authorized dealer itself for better results..ok
May 25, 2009 | Televison & Video
Dvd is not reading
After loading a dvd screen prompts "loading" then "no disc." Even with a brand new disc.
Qaung
Dec 08, 2008 | Philips DVP5140 DVD Player
Disc read error
Sounds like the laser has gone or the try is not fully loading the disc.
Dec 03, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Finalizing dvd after recording
I have also had this problem as well, and have also found that when it is preparing the disc to begin with the player will lock up.
I've only found this problem on dual layer DVD-R discs. I've yet to get to the bottom of this issue BUT looking back at the manual there is a section around compatibility and it has the the following statement:
"A 8X speed DVD+RW or greater disc can be played, but
maximum recording speed is 4x."
The discs I am using are 8x which looks like it could be the problem. I am wondering if the discs are having issues with running at the lower speed.
It may be worth checking the speed of the discs that you are using.
Nov 12, 2007 | Samsung DVD-R155
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
RIM BlackBerry  Pearl  8100 Logo
22 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
