I can't change my computer from 24/16 bit color to 32 bit
  • 1 more comment
  • Wrath N Jul 11, 2008
    I tried updating it and it came up with a message stating that I have the best hardware my computer can find.
    Where would I find that?
    Thanks a lot. I hope it works ^-^
  • 2,427 Answers
The Problem is the Driver that you are using, insure that your driver is up to date and installed propperly. YOu can get the driver at the manufatcures web page or you can use software to do it for you if you and not certin of your hardware type. e.g driver magician, you can use google to find it.
Posted on Jul 11, 2008
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
It says c4 engine and then it says something about 32 bit color . my comp is set to 32 bit color and i have the latest directx so what could be the problem also i have a dual core prosseser and the lastest...
Gentlemen,
I purchased City Bus Simulator 2010 from Fspitot shop under order Number 316737 for $54.50 Canadian and cannot get it to work. I cannot load any passangers and cannot see any yellow bus stops.
I am running Windows Vista on a 64 Bit Computer.
Can you tell me how to solve the problem or direct me to someone who can help. It is a TML product. on a disk. I have been trying to get it to work for 2 weeks now with no success.
Thank you,
Lawrence Hibbard
4602 B-47 Street,
Red Deer, Alberta,
Canada, T4N 1R1
lhibbard@telus.net
403-314-1181
Mar 30, 2011 | City Bus Simulator 2010 York - Windows
How can i change display settings of my lap top to true color 32 bit
Right-mouse click anywhere on the desktop "wallpaper".
Click Properties.
Click Settings.
Change from 16-bit or 24-bit to 32-bit.
Click Apply.
Sep 13, 2010 | Computers & Internet
My computer screen has error message Frequency out of range. This happened when running Google Earth, it changed the color quality from 32 bit to 8 bit. When I tried to change the bit back I get this error...
Right click on the free space in the desktop and select properties. Then go to display properties and change settings to 32 Bit and Change the screen resolution to 1024 by 768 Pixels.
Apr 05, 2010 | Gateway GT5220 PC Desktop
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
I cannot get the Princeton VL 1716 to stay on the 32 bit color when I reboot.
This problem occurs when the incorrect video driver has been install in the computer. It defaults to generic VGA driver which does not allow any scope to change to a higher screen resolution and a higher bit color setting.
Oct 23, 2009 | Princeton Digital VL1716 17" LCD Monitor
How can i upgrade my 16-color to 32-color
Are you referring to color scheme? If so, you should be able to right-click on an empty space on the computer desktop, choose Properties from the menu that appears. Then, in Windows XP, choose the Settings Tab. You should see a drop down menu on the lower right titled Color quality. In the drop down menu you can choose 16 bit, and should have a selection for 32 bit. Select the 32 bit, click Apply. Then the screen should change to that setting and ask if you want to keep those settings. Select OK and you should be good.
Sep 28, 2009 | Computers & Internet
The monitor only displays either 1920x1080 resolution with Low (8 bit) color or 800x600 with High (32 bit) color. I have uninstalled the video card and monitor drivers and reinstalled them a million...
It appears that your video card does not support that resolution and color depth. If you've installed all of the proper drivers from the manufacturer, re-check the maximum specs - sounds like you're looking for HD (1080) and the card can't deliver in full color (32 bit).
Jun 07, 2009 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
