Question about Lexmark X75 All-In-One InkJet Printer
Lexmark x75 I am trying to print a cd label and the status button comes on the printer, it's not allowing me to print. I have uninstalled and reinstalled the program and I still can't get the label to print. It worked fine two weeks ago. Regards, Lee
I DONT HAVE CD PROGRAM THE MY LEXMARK X75 PRINTER
Posted on Aug 25, 2008
The "on-off" light is flashing steadly... while
The flashing light could either indicate a cartridge problem or the printer carrier has stalled.
Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed. To do the hardware test, follow the steps below:
  1. Switch the printer off.
  2. Put one sheet of paper into the paper feeder.
  3. Press and hold the power button and the paper feed button for three seconds until the power light comes on.
  4. Release both buttons. After three seconds, the printer will start to print. You should obtain a page containing a series of horizontal color lines, and a thick black line below these. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not turn off the printer, it will keep on printing this page.
To check if you have a cartridge carrier stall, follow steps below:
  1. First unplug the printer.
  2. Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
  3. Once the cartridges have been moved across, you can clip them out.
  4. Try to print without the cartridges in the carrier.
  5. If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
Try to print a document to check if printer is working properly now.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sources: - Lights Flashing on the Printer - How to Perform the Hardware Test on the Lexmark X74/X75
Jun 25, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark x 75 will not print and status light comes on
This could be a slight communication problem. Try to unplug the printer from your computer. Reboot your pc. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
You can also try to update the printer software by visiting the Lexmark website at http://bit.ly/iSpJjv. Select your operating system, download and execute the file.
May 13, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
My Lexmark X75 comes on and seems ready for printing, but the paper will not feed -- either a single sheet or a small stack of sheets.It won't feed even when I press the paper feed button.
Gave up on you folks because I do not use credit cards and that seems to be required before I'm allowed to ask for assistance.
Thank you, anyway.
gramalee
Jan 22, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 won't work
Contact the dealer since this still under warranty.
Aug 13, 2009 | Lexmark X75 All-In-One InkJet Printer
Is is not printing right. The printing comes out
Go to start->all programs->Lexmark X74-X75->Lexmark X74-X75 Solution centre
Then click on the maintenance tab in the far left corner. then, under Select a Maintenance Tool:,
select "align to fix blurry edges. that should fix it.
Jul 15, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 does not scan or copy from the device nor on the pc
I have to know what are the things you tried. But still i will let you know what you should try. Reinstalling your device by first uninstalling your device and using any disk cleanup utility to clean the disk so that old corrupted files are removed. You can also try to look for troubleshooting help in the software CD which came along your device. you can also go to the companies website for troubleshooting. They will ask for the device code and some information. Usually this error comes when the driver installed for the device is corrupted or gets corrupted.
If my advice helps you out, please feel free to rate me.
Thanks....
Mar 22, 2009 | Lexmark X75 All-In-One InkJet Printer
My Lexmark X75 will print but not copy. When I
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print. Are you copying from the button on the X75 or from the All-In-One Center software on the computer? If the button, try it from the software.
Feb 24, 2009 | Lexmark X75 All-In-One InkJet Printer
How to print labels on my Lexmark X7350
how do i print labels on mylexmark x3350 printer please
Oct 08, 2008 | Lexmark X75 All-In-One InkJet Printer
Power button and status button on same time
sounds like a possible bad printer driver install. can you reinstall the drivers or try a different usb port?
Jul 11, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
