Question about Kenmore Elite HE4 Electric Dryer
Dryer Problem Lint light keeps coming on and dryer will not work
My 2 yr old dryer lint light keeps coming on which causes the dryer not to work. It actually comes on sometimes then shuts off. I have cleaned the hose from the dryer to the wall, vacumed the lint area, washed the lint screen, stuck a hose down the vent going outside. I also have a boyfreind that is no help at all when it comes to situations like this. I would appreciate any suggestions you may have.
  • 246 Answers
When you say you vacumed the lint area, did you mean the lint catcher underneath where the lint screen sits? The most effective way is to remove the 2 1/4" screws on the bottom of the lower front panel. Once you have the panel down and off, you will see a lint chute (the part under the lint screen). Remove the lint screen, 2 more 1/4" screws towards the top of the lint chute on either side and a 1/4 screw on the bottom by the black clip and youcan remove it for best cleaning and also any possible build up around your blower wheel (the white looking fan underneath the lint chute) Can you run it sucessfully without the hose attached? It could indicate a problem between where the hose enters the wall and exits to the outside of the building. (it will get very hot, humid and a little linty doing this test, but it would eliminate any kind of blockage with the venting). When you washed you lint screen did you scrub it? I usually use soap water and an old tooth brush as you can actually get a clear coating on the screen without even being able to see it. How do your seals look? (put your head in the dryer drum and you will see a grey ring both in the rear and as you look back towards yourself) Are they dammaged? Have you cleaned your moisture sensors? This can cause a false error. While you have your head in the drum and are looking back towards the front, you should see 2 silver bars. Clean them off with the abrasive side of a sponge or a fine grit sand paper. If it is still malfuntioning, drop me a note back with your model and serial numbers (loacted just inside as you open the door) and I will see what else I can come up with.
Posted on Jul 11, 2008
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Heads up I found the technician manual for my
Hi there and thanks for your comments ... I seem to spend hours here telling folks about lint, where it is and how to get rid of it. You sharing your first hand experience is appreciated.
Oct 18, 2009 | Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Lint Trap in dryer
ngfam1 At your service!
You said, lint is collecting by vent located outdoors. And you feel, the lint trip isn't working.
and you feel very concerned that this is a fire hazard.
We do clean the lint trip off before every dryer run.
The fact that lint is clogging your outside vent does not mean the dryer is not working properly!
The dryers with the top mount lint screens have blow by lint to the outside.
My next dryer will be a Speed Queen dryer which has the lint screen inside the dryer by the door and works better , without the mess on top of the dryer every time I remove it to clean before each load!
That top filter is an old style design!
The outside screen is to keep small animals out!
I find the new plastic outer vents have a plastic mesh screen which caused the same issue as you spoke of and caused my dryer to stop getting hot even though it was only half blocked outside !
I REMOVED the screen and left it off!
And recommend this to all other folks too!
The dryer is too hot for animals to want to enter! They sense it! AND THEY WON'T go in it!!
There are a few types.
1.The old ones are a aluminum vent with a aluminum flap like door that has a spring to keep it closed when the dryer is not on and forcing it open to allow for the exhaust to escape.
2. The newer ones can have a plastic flap that works the same way ,but usually designed without the spring mechanism.
3. the newest one are the ones with the plastic mesh screen that I spoke of above!
Remove the pop off plastic screen and leave it off!
Or if you have the flap door kind.
Change the vent to the open one that comes with the plastic pop on mesh and do not put the screen on!!
It's been years that mine is off and it's all is fine.
You will be fine
Bless You ,
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
226 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
