Question about Kenmore 62602 Electric Dryer
Kenmore Dryer Model 86873100
All aspects of unit works well but the drum motor sounds as if it is single phasing and the drum will not turn.
  • 943 Answers
Hi thanks for the question it looks to me you have a bad thermal fuse located at the back remove the back panel on the air duct you will see a small plastic piece with 2 small blue wires replace this part thanks the appliance doc
Posted on Sep 16, 2008
Where is the heating element on model # 86873100 Kenmore Electric Dryer Model # 86873100 68731 Serial # M 94966314
Here is the Sears parts site with diagrams and parts listings, look at the Bulkheads parts diagram:
http://www.searspartsdirect.com/model-number/110-86873100/0582/0151200.html
And this might be the right video for replacing the heating element if you need to:
Feb 10, 2017 | Dryers
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Dryer turns on but drum will not spin
Sounds like the belt is bad or the motor needs to be replaced. Unplug unit. When you open it up get a block of wood (a piece of 2x4 works) if your units are stacked on top of each other, pull the dryer towards you approx 2inches. You are going to push on the top of the dryer and insert the board underneath the dryer. The reason you pulled the dryer forward was to keep the dryer from slipping backwards while working on it. Now check the two bottom corners on the front of they dryer.occasionally there are screws holding the kick plate. Take these off, pull out and down and look for broken belts. Be sure to vacuum any loose lint while you have the unit open. Good luck.
Jul 14, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Where is dryer belt on kenmore dryer model#86873100
Check the model number again. That number is coming up as a refrigerator.
Nov 25, 2012 | Kenmore Dryers
Kenmore 68731 model 86873100 setting the drying to any of the drying methods, the dial does not move to automatically turn off the dryer.
You have a bad timer motor To verify you will get an ohm meter and remove the wires to the motor.
Check between the motor wires fer continuity. If you have continuity then the next test will verify if the gears are stripped on the motor. Apply power to the timer motor and see if it advances on its own. From looking at your model number I see nothing unusual about the timer.
to get to the[parts list I did 110.36873100. 110 is a the large prefix which ID's the dryer as being a whirlpool model. All kenmores ain't Whirlpool.
Aug 26, 2011 | Kenmore 659 Electric Dryer
I have a brand new IR compressor model 2475N7.5 with a 7.5 hp 460v 3 ph motor. is it possible to convert it to a single phase power supply? or should i just exchange it? ... I ordered it thru Northern Tool...
When you google home made 3 phase converters, you will find many ways to make use of 220v single phase instead, however you are limited as to the hp that the motor will produce. If you spin the motor first then apply 220v, the motor will continue to turn at much reduced hp. You need full power to turn a type 30 pump depending on pulley combination/ setup. Best to return the unit and get one that will run on 220v single phase. It will most likely consume more power to do the same work however it would cost a great deal to install 3 phase. Most likely not even available at all. Many years ago, I worked at Sears and happened to see an electrician coming down from roof access of building. He told me that sears had a 3 phase generator being turned by a 220v single phase motor to run an air conditioning unit. He said that it worked quite well. Does not sound cost effective.
Jan 08, 2011 | Ingersoll Rand - Rand Type - 30...
Light works has power, won't turn dryer quit without warning. light inside drum is on, there is power to the plug. we had electrical problems (one intermittent dead leg from transformer, utility fixed it...
It sounds like the electrical problems fried the dryer motor. While dryer motors typically have some sort of motor protector, which shuts off the motor if it overheats, these devices self-reset.
Make sure the dryer-cord terminal screws are tight where the dryer cord attaches to the unit, typically behind a small steel panel on the back.
While it's remotely possible that a loose/disconnected terminal is to blame, I would bet that the loss-of-phase killed the motor.
If yours has electronic controls of some sort, that could also be an issue. But if your model is just the old timer-knob type, then I would think it's the motor.
Oct 21, 2009 | Kenmore 500 6952 Dryer
Drye squeaks louldly and smells hot drum stops turning
you have a drum ball that is chrome looking that fails a lot
you need to get the kit and direction from a parts house to fix it ..
mine breakes about every 6 mo
5 boys in the house
Apr 02, 2009 | Kenmore Dryers
Kenmore 62602 Electric Dryer Logo
319 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
