Question about Samsung HTC5500 Theater System
NO OPTICAL SOUND I connected HDMI from reciever to TV, HDMI from PS3 to TV, Optical from PS3 to Receiver (PS3 Sound settings switched to Optical, with Dolby Digital 5.1CH, and Dolby DTS 5.1 selected) Also Optical from TV to Receiver does not work. Only get sound from HDMI to 2 speakers, not 5.1 Receiver Function set to (D.IN)
    Scholar:
  • 85 Answers
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Posted on Jan 07, 2011
SOURCE:
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Separate video and sound on hdmi
yes it would be possible to separate audio and video from your PS3. You would need to go to the PS3 setting for audio and choose Optical instead of HDMI. You would need to connect and Optical cable from the PS3 to the receiver. Then on the receiver you would need to set the digital inut for your source(PS3) to optical.
Mar 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Nov 28, 2008 | Audio Players & Recorders
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Samsung HTC5500 Theater System Logo
474 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
