Question about Bissell Vacuums
My first time using this..I just want to know where the water goes and where the soap goes..I don't have directions..I was looking for the directions on here but don't see it.. This is a bissell proheat turbo.. Thank you/
  • 417 Answers
okay the under the lid of the big tank has a place for regular hot water theres a flexible inner bladder inside the main tank- fill that with hot water. When your shampooing the dirty water fills in around it, also between the back wheels theres where the resolve/bissell detergent goes. we use regular washing machine liquid diluted 50/50 in the soap dispenser , its cheaper and does the same thing..also, if you have pets, the bissels have a brush roller mechanism that gets clogged with pet hair quickly and will self destruct, every few rows stop and see how much pet hair is around those rollers and remove it.
J
Posted on Jul 11, 2008
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
How to clean filters
Most of the Dyson have a filter inside the canister where the dirt goes or under it---it is critical for safe operation--if it gets really blocked the motor will overheat and the thermal cutoff will kill all power to the unit.
It is a white foam type and instructions for washing are right on the ring it inserts into. Wash with water and mild soap (I use dish soap).
I suggest doing in the sink and expect the water to run black for a while----it must be allowed to dry completely and do not use a air compressor to do this.
The foam type filters are washable, I am not aware of another filter in this unit but check the owner manual anyway.
The filter will not "look" real dirty but when you run water thru it you will now know.
Dec 18, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Flow indicator does not spin when the trigger is depressed like nothing is coming through, pump?
Usually that is showing no soap in soap tank even if there is water in the water tank.After filling soap tank make sure it locks in real good ;Thats been my problem a few times.I didnt know the water and soap were in seperate tanks the first 2 times I used mine lol....
Jun 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
I have a Bissell ProHeat Turbo. It has only been
i use white vinegar to clear my line.. and it doesn't hurt the carpet.
check the little filter on the top of the machine (mine is on the right side) if it is full of lint, etc and blocked it will not dispense or pick up.
Mar 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Filling the cleaner
cleaner goes in little tank on side. Hot water only no soap goes in the big tank in middle
Jun 25, 2009 | Bissell 1699 ProHeat Clear View Upright...
Where do i put the soap?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=548073
Posted by dopaMEAN on Apr 26, 2008
I have a Bissell Dirt Lifter that has the giant clear store compartment that you supposedly put the water in?
Do i mix the soap in with the water in this compartment or is there another location where i add the soap..
We have looked the machine over and see no other place to really put the soap...
will it ruin the machine if we just add the soap with the water in the detachable compartment?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
According to your description you do mix the water with the Bissell soap in order to dispense the solution onto the spot, it will not ruin the machine if you mix the water and soap together.
You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
No water or soap coming out
the filter could be block under the flow indicator cap,
but water should still come out of the hose
Nov 07, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
105 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
