How to remove the printheads from a canon i860 printer
  • Anonymous Feb 27, 2009
    need to replace print head on kodak 5100 aio. Dont want to break it and there is nothing showing how to do this. Hopefully someone that really knows will respond and not some ****** seeking attention.
Remove cartridges. there should be a release button near the top of the back facing you. Probably wont be able to see it easily, but can find it easily. Push it and it will release the "click" you heard when installing the print head. Hopefully.
Posted on Feb 27, 2009
With ur fingers
Posted on Jul 11, 2008
I removed the printhead, cleaned it with a damp paper towel and q-tip,made sure it was dry, I then installed the printhead, and turned on the printer. It moved the printhead to the far right as normal,...
Hello!
We must not rub it with any materials, so its head were very sensitive. There is no other way to solve your problem without Changing its head..... good luck
Sep 14, 2011 | Canon i860 InkJet Photo Printer
Driver installation progam says "print head needs alignment" but doesn't say how to do it.
Canon i860
Align printhead automatically:
1) Be sure that the printer is powered on and letter size plain white paper is loaded in the sheet feeder
2) Press and hold the <Resume/Cancel> button, and release it when the Power lamp blinks four times.
The alignment pattern sheet should now be printed out. Wait for the pattern sheet to finish printing.
The printer should stop prompting you for this procedure.
Feb 27, 2010 | Canon i860 InkJet Photo Printer
Canon i860 error code 5200?
5200 is a printhead temperature error, defective printhead You need a new printhead,
QY6-0049-000 around $40.00
Aug 03, 2009 | Office Equipment & Supplies
Canon i860 printer not working
The error code says that your printhead is bad and needs to be replaced. QY6-0049-000 around $40.00
Jun 30, 2009 | Office Equipment & Supplies
CANNON I860 AMBER LIGHT BLINKS 5 TIMES THEN REPEATS. I POWERED DOWN AND DISCONNECT IT THEN RECONNECT IT.. SAME THING.. BWH
5 blinks says that the printhead is not installed. It's just a defective printhead part number qy6-0049-000, around $40.00.
Jun 29, 2009 | Canon i860 InkJet Photo Printer
New printhead will only print 3eBK, no color
If you're concerned with a clogged printhead try to clean it with acetone solution. Also, check the cable connections to your printerheads they might be loosened..
Feb 23, 2008 | Canon i860 InkJet Photo Printer
How to remove printhead from canon i860
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
Feb 01, 2008 | Canon Pixma MP500 All-In-One InkJet...
I860 won't print properly
Buying a new printhead is a mighty good suggestion, it seems you have pretty well used up the maximum service life of your printhead, if i'm not mistaken. Try to reinstall your printer along with its software. Go to settings>control panel > remove hardware> then,reboot. After, rebooting, re-install your printer software and drivers.
Dec 29, 2007 | Canon i860 InkJet Photo Printer
190 people viewed this question
k24674
