Question about JVC Televison & Video
Cannot set horizontal convergence picture has a red tint left overcast
  • 52 Answers
Convergence IC's need to be replaced.
Posted on Jul 11, 2008
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    Green tint to screen
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
    When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
    You can get more information and a DIY convergenece repair kit with instructions from the link below.
    Here are some of the most common problems with these sets...
    Problem #1) Convergence
    Yours may have one or more of the following symptoms...
    *Screen Looks 3-D
    *Colors wont align
    *Screen may look distorted or warped
    *No Audio/Video - TV Shuts down - May also make a constant chirping sound
    Problem #2 - Another common problem is dull or washed out video.
    Your set may have one or more of the following symptoms....
    *Dull looking picture
    *White looking picture
    *Halos around objects
    *Red/Orange looking picture
    bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Apr 21, 2010 | Hitachi 42V710 42" Rear Projection HDTV
    How do you set convergence
    What is your Make and Model number?
    Red/Orange horizontal lines
    it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
    Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
    Red horizontal convergence PT-47WX49E
    converge outputs getting tired or limiting resistors opening up. adjusting this incorrectly will make the situation worse keep in mind that overdriving these chips will cause a fold over of your image when you see this carefully adjust in the opisite direction as you may be overheating the outputs
    Oct 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
    Hitachi 51SWX20B Convergence problem
    Solution:
    Your TV has a convergence problem. Here are some of the most common symptoms.
    Screen looks 3D
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed in or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence or magic focus section.
    Try to adjust the convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Its a fairly easy fix on the Hitachi sets.
    You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
    Everything you need to fix it yourself.
    Jan 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
    Televison & Video Logo
    23 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
