Video Game Consoles & Games Logo
Anil Chaturvedi Posted on Jan 07, 2011
I have pcsx2 and i have ps2 games but they run at low speed not at normal is any solution my pc specs are intel pentium processer t4400 (2.2 GHZ ) webcam 320 GB (7200 RPM)Harddrive 3072mb ddr2 sdram(2 dimm)freedos 14.1 diagonal wxga (1200 x 800) intel r 4 family chipset intel GMA 4500M WITH SHARED GRAPHICS MEMMORY RAM 3.00 GB OS : WINDOW 7 32 BIT
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Sep 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
926
Points
10
You just need to type in inside google "pcsx2 t4400" there will be an youtube video showing up, it shows how to get 50-60 speed in games like kingdom hearts and ff.
for more help you can contact me on my youtube channel: TheEasyGuitarTabs or nodenx22 on psn.
Sir, i want to sound driver 845gv/gl intel i download many driver but not support, please help me
You can play both Playstation and Playstation 2 games on PC using emulator softwares.We don't support piracy here so do this only if you have a original Playstation disc.And you will need to dump your bios from your own PS2,since the emulator needs those files to play the games on your pc.For further details on how to configure the emulators you can checkout the forums and official websites of the emulators themselves.
Here is the link for PS2 emulator http://pcsx2.net/downloads.php download the first one named
pcsx2 0.9.6 installer.And here is its configuration guide http://forums.pcsx2.net/Thread-Official-English-PCSX2-configuration-guide-v0-9-6
That was for Playstation 2,if you want to play only PlayStation 1 games then download epsxe from this page along with the config utility http://www.emulator-zone.com/doc.php/psx/epsxe.html
Thanks for using Fixya!
I am having pc with intel pentium 4 processor and my motherboard is asus p5gl-mx .. i like to play the play station 2 games in my computer what should i do ..tp lay the games in my computer....please any...
You can't play them directly, the games are designed only for the PS2 special software and hardware, and they can't be converted.
You could simulate a PS2 in your pc and load in it a game, but unless your pc is a top of the line one (powerful processor and video card, lots of RAM) it will run very slowly or not at all.
Try it to see for yourself:
http://emulator-zone.com/doc.php/ps2/pcsx2.html
2helpful
When i run pcsx2 it says your pixel shader is too low
Your video is not capable of handling the required pixel shader to run pcsx2 for emulating PS2 games.
You're lucky if your video card can be upgraded. If not, you better look for new video card. I believe PS2 emulators requires at least version 2 pixel shader.
2answers
Can I run Playstation 2 games on my PC without a PS2 console.
No, but you can buy PC games that our the same as Ps2 or 3 games
10helpful
3answers
How to install wwe smackdown vs raw 2009 ps2 game on pc
For PS2 emulation: You can play by using PCSX2 0.9.5 latest version, but your pc must be strong enough to hold it. You can download it at www.pcsx2.net.
You need the game to use the emulator. Also understand you need a powerful computer to run these games on your computer.
Question regarding playing a game of ps2 on pc
download a software called pcsx2,search google ,make sure to check the compatibility list of games, not all games work perfectly.
u also need to get the ps2 bios search google for those too.
add them to the bios directory(in the pcsx2 installation folder)
and follow instruction on the pcsx2 site to configure the program
2answers
Run ps2 games on pc
Download the PS2 emulator software.....called PCSX2......of course u need 2 have a PC with a good config to play PS2 games
PCSX2 ------- ...download it from
http://www.pcsx2.net/downloads.php
This one is a very good video tutorial,
http://youtube.com/watch?v=eqXp65lW-SE
Recommended config:
CPU: core2duo 2.66Ghz Wolfdale or higher
RAM: 1GB
GPU : nvidia 8600 GT or higher
Cheers
8helpful
3answers
PLAY PS2 GAMES ON PC
Ok, you want a full procedure here it is. First of all if your computer does not meet the following specs stop reading cuz you'll be wasting your time trying to get it to work and will be very disappointed by the quality of game play:
Minimal Specs:
AMD 64 or Intel Pentium 4 (VM Build will not work with non SSE2 CPU's)
512MB of RAM
Pixel Shader 2.0 supporting card
Recommended Specs: (For reasonable performance in many games, but not all)
AMD64 X2 or Intel Conroe E6600+ (Multi Threading is supported in PCSX2)
512-1024MB of RAM (more RAM allows for VM mode to be stable)
Pixel Shader 2.0 supporting card (recommended GeForce 6600-8800 or equivalent ATi card)
Possible Ideal Specs:
64bit OS such as Vista or winXP64, to allow for future support of 64bit recompilers.
Future AMD or Intel Quad Coremaybe needed, but currently the support of 4 threads is not handled byPCSX2, and the effect of threading out EE / VU is not yet known.
We don't forsee you requiring a GPU more powerful than the current generation of cards, up to and including the nVidia GeForce 8800.
Also note, if if have just a standard AMD Athlon (non64) don't even bother trying to run this emulator. It does work but is very very slow.
If you meet at the very least the minimum specs go here and download PCSX2 Binary. .::CLICK HERE::.
This is the BEST PS2 emulator currently on the net. There is NONE better.
Next: as with any emulator you need a BIOS in order to use it. There are several methods to getting a PS2 BIOS. You can google "PS2 BIOS download" or check torrent sites like this one .::HERE::.and do a search for "PS2 BIOS". At any rate, get 1 or many BIOS(one for each different area ex. Japan, US, Europe)
Next: Un-7zip the PCSX2 7zip. Take the BIOS.bin files you downloaded and place them all in the folder, "bios" in the PCSX2 folders you unzipped.
Next: You'll notice two icons that look the same one is called pcsx2.exe and one is called pcsx2t.exe. I have had no luck getting anything to play worth a **** on pcsx2.exe. I use pcsx2t.exe. According to the person who made this program, pcsx2.exe is a faster emulator version, but he says that AMD people have had better luck using pcsx2t.exe. So, if your computer has an AMD processor try the pcsx2t.exe first. But keep what I said in mind cuz you may have to use the other one instead. In either case, choose one and run it.
Next: When the program opens, it will have to be configured. Look at the top of the program and click the, "config" menu option. Next click the, "configure" menu option. You are now faced with several configuration options. I'm not even going to bother explaining what each option does, go .::HERE::. it explains what everything does. 9 times out of 10 when pcsx2 won't work, it's cuz of a bad configuration. SO MAKE SURE YOU READ THAT WHOLE PAGE.
As you can see there two ways you can load a game. Either by turning the game itself into an ISO or from using your DVD-ROM drive.
As far as controlers go, you can purchase USB PS2 look alikes from most computer stores. You can also get PS2 to USB converters that you can plug directly into your computer. And there is even a SIAXIS driver floating around on the internet that will run a PS3 controler as if it was a standard computer game controler. If you don't have money for a controler or what not just use the ZeroPAD option under, "First Controler" and start binding keyboard keys to assigned slots.
As with any emulator nothing is perfect and this will not play every single PS2 game out on the market. However, this is the most current emulator in production atm and is the furthest along. When you get everything up and running you'll want to look ..::HERE::. at the compatibility list to make sure your game is registered to even work with this emulator.
Hope that helps,
L8er
2answers
How to plat ps 2 games on pc
->P4 processor is ok.
->You require XP sp2.
->And u need intel duo core processor for better working of ur      games.
->Graphics card should also be installed in it.
-> 1 GB RAM is good but 512 MB RAM is sufficient.
-> and also u require PS2 emulators to run your ps2 games on pc.
Download it from here:
http://www.emulator-zone.com/doc.php/ps2/pcsx2.html
All the best..
2answers
How does I run the ps2 games on pc ?
http://www.emulator-zone.com/doc.php/ps2/ There are 3 different emulators there. I haven't tried them, so I can't say how well they work, but if your hardware can handle it, one of those should play your PS2 games.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
