Question about Dell Inspiron 8600 Notebook
Hard drive I bought a bigger hard drive for my laptop. need to know how I was to formatt it in fat or ntfs?
  • Dell Master
  • 6,487 Answers
If you wll be using the new hard drive as the main drive where the operating systme is you just need to run or install again your operating system and all other applications and I will recommend you formatting it to NTFS because NTFS is more secure comapre to FAT32... You can format it when you run the setup CD for your operating system..
Hope that helps........
Posted on Jul 11, 2008
What should be the standard format for portable HDD? is it NTFS or FAT? and does this affect the loading performance on computer specially when retrieving files on it?
Depends on what you want to store on it. FAT can only handle files that are less than 2GB. If you want to put bigger files on it then NTFS is the way to go. NTFS is usually faster than FAT, but for compatability with older computers (Win98 or earlier) you probably should use FAT32.
Dec 31, 2013 | Computers & Internet
USB EXTERNAL HARD DRIVE
What format has the drive been formatted in? NTFS or FAT? If it is NTFS it won't work, NTFS is the default format of most modern OS. You need to back up the data and re-format the drive to FAT format and copy the files back on to it.
Mar 09, 2012 | Computers & Internet
How can increase memory/speed on my Acer notebook? What is 'FAT 32'?
memory is a hardware upgrade which usually plugs in into the bottom of the laptop. If you look on the bottom you will see a couple doors that unscrew and, but depending on the laptop you will be limited to how much you memory you can add. Also since you are asking about fat32 I will assume your laptop is at least 6 years old (FAT32 is the format of the hard drive, old DOS used FAT, when Microsoft released windows 95, it made options for bigger hard drives called FAT32, then with the release of Windows NT and later Windows machine use a hard drive format called NTFS. NTFS is still the current disk format even with windows 7) NTFS is more secure and can handle very large hard drives. If you let me know what ACER you have I can let you know how much memory you can add.
Nov 29, 2010 | Acer Aspire One PC Notebook
Formatting a Fantom G-Force drive from NTFS to FAT 32
my computer> right click on the terabyte> select format> make sure u change the option of ntfs to fat 32
May 27, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
I have a WD My Book Essential. I have been trying to format it to be compatible with my ps3 but nothing seems to work. I tried to format as FAT32 but now I have a message saying I have ''no writable disk...
Assuming PS3 works with FAT32, format the hard drive using the WD's FAT 32 formatter. Call WD and they will direct you to the correct download location for your hard drive.
Please rate if helpful.
Thanks
May 16, 2010 | Western Digital My Book Essential Edition...
Iomega fat 32 formatter program does not allow me
If you really must have fat 32 (maybe for MAC use ?) then windows itself does not support doing a fat format on large drives.
However there is a fix Yup thats why they call it FIXYA
Here is a link to just what you need
Hope its what you need and good luck
Nov 20, 2009 | Iomega 250GB Ego Portable HD Red 250 GB...
Misinformed
try to format ur harddrive again with selecting NTFS file format...... i hope that will fix ur problem
Nov 10, 2009 | Computers & Internet
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Formating original fat 32
Format the player to NTFS and it will solve the issue.
All the best!
Sep 27, 2008 | INOi HD350 USB 2.0 Hard Drive
Dell Inspiron 8600 Notebook Logo
67 people viewed this question
Alun Cox
