Question about Gateway GTW-P42M102 Television
Menu stuck on and scrolling
The TV remote control will not operate the TV, and now the menu is stuck in the on position and is scrolling by itself? my tv have same problem the menu stuck on and scrolling . the remote dose'nt work.
    Problem Solver:
  • 6 Answers
The menu button on the top of the tv is sticking.I unplugged the cable to the main board for the buttons on top of the tv.worked perfectly.I only use the remote anyways.of course I unplugged the power cord before working inside the tv.easy fix
Posted on May 09, 2013
    Genius:
  • 1,847 Answers
Have you replaced the battery and checked.
Posted on Jul 11, 2008
  • Legin Varghese
    Legin Varghese Jul 11, 2008
    these are the few possiable reason for the remote not working...
    1;resolder battery contacts on PCB and physically
    reinforce.
    2;IR LED solder joints,sometimes IR LED failure (solder any old
    red LED in parallel to check).
    3;Broken tracks from being sat on/knelt on
    4;failed ceramic resonator,check
    by replacing with any old resonator before
    aquiring the correct frequency.
    5;Gradual failure of the most used buttons-worn
    conductive pads-see hints and tips files.
    6;Sudden loss of some functions due to break in track in
    the keyboard multiplexing.
    7;Very rarely is the fault in the main IC.
    8;The most common problem is spilt liquid corroding the contacts,
    through-board jumpers or pcb tracks.
2 Suggested Answers
  • 11 Answers
SOURCE: menu stuck on and scrolling
did anyone ever get this problem fixed with the gateway menu problem i have the same issue
i cant believe noone has fixed it yet...........i have 2 exact gateway tvs one has a bad image board and the other does the menu thing..i want to know which part to swith to get the menu to stop scrolling all the time
Posted on Jan 24, 2010
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
TV scrolls through inputs and menu after turning on. Will not stay on any input.
Main system control memory IC is faulty. Replace it. Contact any service technician. http://electronicshelponline.blogspot.com/
Mar 25, 2015 | Televison & Video
I received an LG 32LX4DC Flat Panel Television from a hotel. It came with a control box LG LST-4100A. I saw on fixya.com the method to access the installer menu. However, I could not get the hidden menu...
Just an FYI if anyone is having this same problem a factory reset will solve the issue.Follow the above directions... "1. Press MENU repeatedly till it seems to not respond. 2. Enter 2-6-6-3 on the remote then Enter 3. At the top, it says ENTER PASSWORD 0000 4. Enter 9-8-7-6 then Enter 5. Installer Menu comes up scroll through the options until you see "factory reset" change the value from a 0 to a 1 with the arrow keys and then power the TV off. When you turn it back on it should be reset to factory defaults.
Mar 20, 2011 | LG 32LX4DC 32 in. LCD Television
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
The most common cause of the problem is a stuck/shorted button either on the television or on the remote. The worst case scenario is a faulty key control board. Remove the remote control battery or put it away from the television. Press the menu button on the television and check if the menu scrolls by itself. If yes, the DOWN button is stuck or shorted. You can actually hear or feel it click when pressed if it is not stuck.
Open the back of the television to gain access to the key control board. You can either repair/replace the faulty button or replace the key control board. Remove the screw holding it to the television casing. Disconnect the old board and install the new one.
Replace the remote control if the buttons on the television control are working properly.
Jan 16, 2010 | Haier HP42BB 42 in. Plasma TV
Piva ptv1502 screen keeps cutting off while playing can you fix problem?
If it's a V-Chip, Parental Control issue, here's the solution. Make sure RF coaxial cable is connected to TV. Press "V-Chip Menu" on the remote. On Password, press "Enter" on the remote. In Password, enter 666666, then press "Enter". Scroll down to "Modify-PW" by using CH+ or CH- key, then press "Enter". Enter 000000, then press "Enter". Select" V-Chip Menu" to exit V-Chip. Select V-Chip Menu again. On "Password", press "Enter" key on remote control. Enter 000000 in "Password", then press "Enter". Scroll down to "V-Chip", press "Enter". TV should display a list of all TV ratings. Use CH+ or CH-, scroll to TV-Y. Then press "Enter" key on remote. Be sure that all ratings are set to "On". Repeat the steps above and set all ratings to "On". Then select "Exit", press "Enter". Press V-Chip Menu" to close on-screen menu.
Oct 30, 2008 | Televison & Video
Magnavox 26MD255V/17
Try unplugging the set for 2 minutes first then try operations again. If that doesn't fix it maybe one of the buttons on the TV is stuck or the remote control is sending erratic commands.
Apr 08, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Mar 04, 2007 | Gateway GTW-P42M102 Television
Open Questions:
Televison & Video Logo
292 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
