Question about Whirlpool Refrigerators
Fridge not cooling properly set all the way to coolest setting freezer seems to be cooling ok
    Novelist:
  • 121 Answers
Check coils underneath may be dirty, if frost in frz. back wall then you have a defrost problem. make sure door was not left open (accidently). make sure door closing properly and gasket is sealing properly. check to make sure light turns off when door closed. hope this helps if not contact us with any additional info. needed. thank you for your time.
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE # 8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair
EMAIL custmomerservice@allbrandsappliancerepair.com
Posted on Jul 11, 2008
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
How so get the fan uptop in the freezer compartment to work, seems the fridge is working, the compressor turn on and the everything freezes and the lower section of the fridge does not cool.
You will need to unplug the wire connector to the fan motor and check for power, you should have 120 volts when the fan is in running mode. To get it running mode turn the cool to the coolest setting when opening the freezer door tape or hold the door switch closed fso the fan will try to come on. If the fan has power but does not come on replace the fan motor.Here is a link that should help http://appliancehelponline.com/refertopevapfan.html
Sep 10, 2010 | Frigidaire FRT21H8 Top Freezer...
Ny aeg fridge is not cooling now showing +12 oc all lights on & display seems OK I can hera a slight "girgling noise from within the fridge
Hello,turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Thanks
May 30, 2010 | Refrigerators
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
