Question about Motorola Talkabout T5400 (14 Channels) 2-Way Radio
MOTOROLA TALKABOUT T5400
My radio will turn on but the monitor is blank. Also the radio will not receive or transmit.
  • Motorola Master
  • 1,654 Answers
First check your batteries. Try the battery pack from a known good radio. If you do not have a battery problem, your issue is probably non-reversible. Sorry. This style radio is non-repairable. The repairable Talkabout units include the Distance, Distance DPS, the TA-7400 and TA-7200.
Posted on Jul 17, 2008
Talkabout MH230R does not Receive or Transmit on channel, can just Transmit (only clicks when Recieve) when programmed 2 channels higher (i.e. all radios on 5-3, one is on 7-3)
Strange. Could it be any of the radios are from different countries? The channels are not worldwide. For instance, Canadian radios are on different frequencies than USA radios. They look identical.
Dec 30, 2015 | Motorola Talkabout MH230R 2 Way Radio
Can you make a baby monitor out of the Motorola 250 model
hello yes you can use these as baby monitors .set one with vox on turn its volume down completly set the channel you require ,secondly the receiver radio set to same channel and that is it though i should state that these radios transmit on pmr band 446 mhz which is widely in use by many people nationwide so they can also listen in to whats been transmitted from your home not very private im afraid !! I would suggest you purchase a wired system hence more privacy and peace of mind hope this helps you
Nov 24, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
I have a Motorola Talkabout T5419 not receiving
motorola has extra security and will not operate with other radio makes very well. It must be locking out the uniden radios.
Oct 27, 2009 | Motorola Talkabout T5420 (14 Channels)...
One radio not recieving
You need to check your interference eliminator code. It sounds like they are not set to the same code. Also, if your radio has a Qt filter, set it to zero.
Here's a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Aug 11, 2009 | Motorola Talkabout T5400 (14 Channels)...
Motorola Talkabout Distance DPS Monitor Button Dead
To remove the button properly/safely, you will need a frame removal tool. This extracts the component board from the radio, and then you can get to the back side of the button assembly. This tool is available for around $5-$7 at most Motorola dealers.
Note: The monitor button is not frequently used, so if the PTT button is working properly, I would not be concerned with the monitor button. The purpose of the monitor button is for the user, when using the radio with the "interference code eliminator" turned on, to be able to check for radio traffic on the frequency before transmitting. Very seldom is anyone so polite as to check.
If you are needing to have the unit repaired, here is a link to some info: http://www.eradiostore.com/cart/images/repair_request.pdf
Jan 10, 2009 | Motorola Talkabout Distance DPS (10...
AC/DC MISSED
The only charger shown as available for the T5400 radio with NiCd battery is the following kit: http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catProductDetail&productID=53614&&showAddButton=true
It includes the dual drop-in charger and 2 new batteries. You can order directly from Motorola at the above link.
Dec 08, 2008 | Motorola Talkabout T5400 (14 Channels)...
Motorola Talkabout 5700, 60 second timeout?
The 60 second timeout is a feature which is necessary to keep from burning up the final amplifier in the unit. It keeps the user from ruining their radio. Most radios, including business radios have this feature. Continually holding down the PTT will also run the battery down very quickly.
It would be best to try getting a regular baby monitor.
Oct 31, 2008 | Motorola Talkabout T5720 (7 Channels)...
Neither radio will receive or send
The radio probably needs reprogrammed to match the other units. Check your owners manual for instructions.
Oct 18, 2007 | Motorola Talkabout FR50 (14 Channels)...
Hello, There is not compability issue, sounds like you have a mic problem because you hear the Roger Beep and that means that the transmition and Reception cicle is working if you could test an audio accesorie would be great. There is another possibility if one of the radios is out of frequency you could experiment the same symtoms.
Apr 16, 2007 | Motorola Talkabout T5400 (14 Channels)...
Motorola Talkabout T5400 (14 Channels) 2-Way Radio Logo
163 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
