Question about GE Spectra JGBP35 Gas Kitchen Range
Right front burner control
The right front burner control (not the knob) came loose, not fixed to the stove like the other three and the gas will not shut off. Don't ask me how I confirmed this, it involved a lighter. I have turn off the gas at the back of the stove. Needless to say I have to replace the burner control. Is that something I can do? If so, where do I find the part and how do I do it?
OR am I calling GE repair??
Thanks in advance for your help.
John
    Problem Solver:
  • 10 Answers
Its gas. use only qualified engineers for this repair you only have to see what happenson a diy fix once . im corgi registered but will not give out soloutions for gas work.
Posted on Jul 11, 2008
Ceramic stove top knob not working
Are you referring to the spark, or the gas flame? Are you able to turn the faulty burner on low, and lite with a match? You most likely need the spark switch replaced. Pleazer Appliance...
Apr 19, 2014 | Kitchen Ranges
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Apr 29, 2012 | Kitchen Ranges
Left front burner not igniting...no spark but has gas,
automatic re ignition control (spark module), that's a common issue on all viking stove.
appliancesrepairla.com
May 12, 2010 | Viking VGIC485-6G Gas Kitchen Range
Short in knob
Replace the spark switch module on the bad burner.
Sep 29, 2009 | Amana AKS3040 Gas Cooktop
Right front electric stove is stuck on high without shutting off, regardless if knob is switched to off. Needed to unplug the stove completely from electricity.
it depends on the model and manufacturer of your stove .. some have solid state relays that could be shorted (usually computer controlled stove) or a conventional relay (for cycling) that may have a stuck contact .. if its a conventiional stove with spiral cooking surface (not smoothtop) .. then you can make sure the burner is not hot and the stove is unplugged .. then you can simply lift and pull the burner out of its socket .. that will get you working temporarily on the other burners until ;you can fix the problem .. that burner could have an internal short to ground .. easy to check with an ohm meter or by substitution of one of the other burners .. if another burner does the same thing then suspect the relay or control switch ... if the substitute burner works properly then replace the defective one ..
Sep 28, 2009 | Kitchen Ranges
Burners not lighting
You have one or more spark switches defective or a loose wire to the switches.
They are located on each gas valve stem.
Yes they should be replaced for safety.
In the interim you can match light the surface burners.
Feb 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JGBP35 Gas Kitchen Range Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
