Question about Ryobi Multi-Volt Battery Charger
Ryobi saw repair part 6570097
I am tring to find this part to fix my saw 6570097 it is the brush holder
  • 550 Answers
Ryobi web site lists the new part numbers for consumables, but by saw model
go to
https://www.customernation.com/pls/ps/ps.ps_main?p_host=329&p_supplier=5060&p_parm=PSHPP
and put in the model number of the saw, and it should punch out current part numbers
Posted on Jul 30, 2008
My ryobi 18v reciprocating saw will not work just makes one qucik high pitch sound and then dead. battery is fully charged.
The mechanic is blocked internal try if the the I think to hear the commentator of the anchor is overloaded to the sound think the wiring of the electric field and brush holder very hot seen that many parts have sliding contacts , turn the fin of the armature between the ventilation hole to see if its not blocked .
Jan 16, 2016 | Ryobi 18 V Cordless Reciprocating Saw
How do I fix the spring on the switch for a 10 inch ryobi miter saw? I can hear it rattling around and the switch won't work. Also plastic screws holding handle together are broken.
Hello Anonymous,
First locate the model number of your Ryobi Miter saw... then search Google for Ryobi Miter saw replacement parts... one result I got is below:
http://www.mastertoolrepair.com/ryobi-power-tool-parts-ryobi-miter-saw-parts-c-873_895_937.html
Try that link, select your Ryobi saw model and zoom into the provided drawings so you can locate the switch, screws, and spring (if needed). The part numbers are supplied and you can order them online easily on that same link... Then just repair your saw with the new parts. As you already noticed, the saw is easy to disassemble and get access to the parts for repair. Have fun and good luck...
RYOBI Miter Saw Parts
Mar 10, 2015 | Ryobi 10 In Miter Saw With Laser
My Ryobi scroll saw made a pop sound when I was using it. Now it won't go. How do I fix this?
pop as in electrical pop? if so it sounds like a brush problem at the commutator. If it is worth fixing cost wise electric power tools can usually have brushes repaired if you know how.
Jan 24, 2015 | Ryobi Saws
How do I replace the fuse on a Ryobi 10 inch table saw (BTS16)?
Repair manual.
As I see it there is no fuse or circuit breaker. Some motors have self resetting thermal breakers but i see no mention of one.
The operators manual trouble shooting section mentions checkin fuse or circuit breaker but did they mean a fuse or breaker in the saw or supply line. If it has had much use I would check the motor brushes.
Repair Manual
http://www.ereplacementparts.com/images/ryobi/BTS16.pdf
Operators Manual
http://www.homedepot.com/catalog/pdfimages/09/09e90711-9fa6-414f-8a87-7392af29a48e.pdf
Sep 27, 2014 | Ryobi Saws
Replacing the brushes in the RTS10 10 inch Ryobi table saw
Take right side panel off (right as looking at front of table saw). Side panel will be held in place with 8 small Phillips screws. Take flat screwdriver and unscrew round brush holder on either side of
motor. Brushes are held in place with springs and fastener. Flick small fastener with fingernail and fastener and spring should pop out. Pull out fastener/spring/brushes(all one piece). Replace with new brushes (about $8/piece on ebay).
Mar 18, 2014 | Ryobi 10 in. 15 Amp Table Saw RTS10
My ryobi BTS10 won't start.
The Ryobi does have an overload protector (PN 452110003) inside the switch box. It should be resettable from a small hole to the right of the switch on the front of the cabinet. If not, you may have to go into the switch box to check it out/reset it. If the overload protector is OK, I'd check the condition of brushes and brush springs next.
Jan 21, 2013 | Saws
How to replace brush holders on dewalt table saw dw745
There is a small allen screw in the field housing holding the brush holders in.
Most often I have found, if the brush holders are needing replacement the motor housing also needs replacement - they heat up and the plastic cracks.
Dec 26, 2012 | Dewalt DW745 10" Compact Job Site Table...
If one of the brushes is worn down to half the size of the other will this stop the ryobi saw from working having no power at all
Replace the brushes. This is easily done and the parts can usually be obtained from a specialty tool store or perhaps directly from the manufacturer. Check the Ryobi website and see if you can either get a spare from them or if not, they may have a list of tool repair shops in your area that can get you the part.
Jul 18, 2011 | Saws
My Ryobi 10 inch miter saw, model TS 1340 has been working fine for years, now in the last 7 days, I see heavy sparking at the carbon brushes and a drop in power from the saw, there is a strong smell of...
It sounds like the armature has developed an open commutator bar. What did the brushes look like that you took out. But before I assume the worst I would unplug the tool and remove both brushes and with a flas light look into the brush tube while slowly rotating the armature looking for a discoloration or raised bar. If not you might bet by with cleaning the commutator with a special stone for this, you might be able to get one at the repair shop where you bought the brushes. If you want to send me the photo of the arcing it might help on my end. Let me know
Mar 09, 2009 | Ryobi Saws
Ryobi Multi-Volt Battery Charger Logo
186 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
