Question about Casio Exilim EXZ75 Digital Camera
Battery Problem I've had two batteries short out within 6 months. Am I doing something wrong
  • 34 Answers
If these are the NP-20 batteries chances are, you are not doing anything wrong. There is an issue with them which is currently trying to be resolved.
Posted on Aug 21, 2008
I have a 2001 KIA Sephia I've had within the last 2 months the timing belt replaced, the fuel filter, pump & relay switch replaced, alternator and a new battery put in and it seems like I'
This will need a hands on inspection by a qualified mechanic. i suggest the Kia dealership, but at a minimum it needs to go to a different shop than the one you've been taking it to as they seem to not know what they're doing.
Mar 22, 2017 | 2001 Kia Sephia
I have an HP G60-235X that I purchased a little more than a year ago. About 6 months ago, I began to notice less charge life in the battery and a very high temperature from the battery pack. Now, and...
You need a new battery. One or more cells is defective. Obviously it's unsafe to continue using a battery pack if it gets hot enough to cause burns, so remove the pack from the computer. You can continue to use the computer on AC power until you get a replacement battery.
You might try contacting HP to see if there's any kind of warranty accommodation they can make. I've found several mentions in various forums about batteries in similar models going bad and that HP replaced them, but they were all within a year of purchase. Can't hurt to ask, though.
Jul 09, 2011 | HP G60-235DX Notebook
I Have a 2005 4Runner and every 3 months for the past year and a half the battery dies if the car sits for a few days. I have taken it to the dealer and another mechani and both have kept it over night,...
under the dash interior lite is being left on. try checking it out
after dark to see if that might be the case. also, power is
still supplied to your radio, and powers memory, could be
a short in the radio. even though the key is off.
Sep 26, 2010 | 2003 Toyota 4Runner
I ve not used camara for 6 months put new batteries in but it will not turn on .allen
Make sure that the battery terminals are clean and there is no crust in the contacts. Make sure the battery is of the same type/same rating for the camera to switch on.
If the camera does not turn on still, try to put the camera in a warm place for some time to ward off any moisture within. Repeat to ON.
If not you will need help to get the camera opened and checked within. The fault can be a simple link to the failure of the controller.
Sep 17, 2010 | Nikon Coolpix 3200 Digital Camera
2007 yukon. battery goes dead in a few hours. It will do this about once every 6-12 months. Doors lock themselves when no one is near vehicle and keys are out of ignition . Does this every few months
I think you have what is called a parasitic drain. First check to make sure the light in the glove box, under hood, indicator light showing door is ajar, interior light ect all go out when they are suppose to.
If this is something that happen only once every in 6 to 12 months I think you are probably dealing with something that is human caused, something left on and not a mschanical issue. If it happens repeatedly when it does occurs then your parasitic drain is probably more of a short in the system. You can disconnect the negative battery cable to prevent yourself from getting stuck when this is going on. When this is happening you pull fuses for various systems and see if the battery still discharges the next day. If the battery is discharged the next day then those systems whose fuse were pulled are not involved. If the battery does not discharge then you have identified which systems are involved. Again this works only if you are having the battery discharge repeatedly.
Feb 10, 2010 | 2007 GMC Yukon
HTC S710 - Battery issue
Hi guys
if u buy new battery for around 35$... its creepy thing that it again sucks within
6 month
so follow these procedure that i really got good response
1)Buy the new battery from any other dealers (u can use Nokia (std) or LG, Micromax, Onida... etc)
having same specifications as 1050mAh Lion-POLYMER 3.7v and having equivalent Size that fit into the case.
2)Now open ur dead battery, remove the sticker slowly, u wil get the polythene bag carrying the charge sheets
3)Please note that dont not disturb this polythene bag... (cutting, drilling or pinning), else it starts burning.
4)U will see a circuit above the polyhthene bag having two poles (+ve n -ve) just cut the poles of bag from the circuit and keep the bag aside
5)Now do the same procedure with new batt and remove the polythene bag.. and soilder with
the dead battery circuit. (check the +ve n -ve by multimeter)
5)Re-assemble with insulation tape and recondition it perfectly.
now check poles bofore starting.
Note : i got good result from this and i m getting 18-19hrs standby and 11-15hrs usage. Do it on ur own risk...and i m not responsable for ny harm)
Jun 02, 2009 | HTC S710 Smartphone
Batteries keep dying
A short somewhere. All shorts can lead to fires, so take it to the dealer or go to a mechanic who does electrical work such as a starter shop.
Dec 21, 2008 | 2004 Scion xB
Boat battery 12 volt drains down in few days. I hooked up volt meter in line positive wire to circuit to elec lift, it shows just under 1 volt steady with switch in off position, could this be the drain on...
1 - isolate the swithc completely
2 - remove the +ve terminal from battery
3 - conduct continuity check between +ve & -ve lines from on any lines possible.
A short is unlikely, as this would either blow a fuse, or cause you a fire.
It does sound like you have something that is draining power constantly, or you have something that has risen in resistance (water environment can cause verdigris and bridging to occur) this is not enough to power the given unit, but certainly enough to drain a battery.
HINT - Apply vaseline to any exposed copper or contact points.
Aug 17, 2008 | Audiovox AVP-7000 Video Cassette Player -...
Short Battery Life
it is the matter of battery life time-nothing wrong
Aug 05, 2007 | Sharp EL-9600C Calculator
Casio Exilim EXZ75 Digital Camera Logo
23 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
