Question about HP OfficeJet 6210 All-In-One InkJet Printer
Out of paper message
I cleaned the rollers and changed and re-loaded paper, you helped someone with check skew parameters? How do I do that?
  • 446 Answers
There is a paper guide that supports paper on the tray, if you look closely you can even see the paper sizes that corresponds with your printer either (lettter size or 8 1/2 x 11) if this is not set correctly then you can get skewed on your prints, if i understand you correctly, or kindly elaborate some more
Posted on Jul 24, 2008
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
I have an HP Photosmart C8180 All-in-One that was purchased in 2008. I have using it to scan slides and create JPEG files from which I have been making prints, mostly 4x6 format. Just today for the first...
Issue The All-in-One is working, but the printed output is not straight on the page. It is skewed or crooked. Solution Follow these steps to resolve this issue: Step one: Ensure that the paper is loaded correctly
  1. To make sure that the paper is loaded correctly, check the following conditions:
    • The right side of the paper is even with the right side of the paper tray.
    • The paper guides are adjusted to the edges of the paper.
    • The paper is flat in the tray.
  2. Make sure only one type of paper is loaded in the All-in-One.
  3. Make sure the rear access door is securely installed.
Print a diagnostic page If no identifiable problem exists with the paper or the guides, print a test diagnostic page to see if the unit is operating correctly. Follow these steps to print a diagnostic page:
  1. Load letter, A4, or legal unused plain white paper into the input tray.
  2. Touch the Setup icon on the display.
  3. Touch Tools .
  4. Touch Self-Test Report . The HP All-in-One prints a Self-Test report, which might show the source of the printing problem.
Validate that the printer is within skew tolerance Follow these steps to validate that the printer is within skew tolerance using the self test report:
  1. Fold the paper horizontally into half. Look through the paper to see the single and double lines at the top and bottom of the page.
  2. The line over the single line and the line below the two lines should overlap exactly.
  3. The single line at the top of the page should fall between the two lines at the bottom of the page.
Step two: Clean the paper rollers Follow these steps to clean the paper rollers:
  1. Turn off the unit and unplug the power cord.
  2. Remove the rear access door.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around.
  4. Allow the rollers to dry completely, and then replace the rear access door.
  5. Plug the unit back in and turn it on.
Step three: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. If this does not resolve the probelm I suggestsdownloading the HP Print Diagnoostic Utility:
Trust this will be helpful. :)
Dec 11, 2010 | HP Photosmart C8180 InkJet Printer
When I print something on my hp 6210, the words and pictures are bisected and skewed. Why is it doing this?
You may have a paper path problem, if the paper skews during printing you will get skewed lines, try cleaning all the paper path rollers you can access, look for any paper debris.
Jan 03, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Dell 1720dn laser printer
If the paper intake rollers are slick and grab paper on an angle, the feed causes the paper to move off center. Rubbing the rollers with a cloth and rubbing alcohol will clean them. Slightly rubbing the entire roller with a fine abrasive material can help with the paper path issue.
Feb 07, 2018 | Dell 1720dn Laser Printer
Rollers should be available; you replace the whole roller, not just the rubbers.
This is a common problem. If you've checked the side guides, change the rollers, but this type of problem is sometimes uncorrectable. Some printers just don't like some paper.
Jun 16, 2008 | HP Business InkJet 2800 Printer
Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
The above illustration shows a PIXMA MP500
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Out of paper message shows for any paper I load
Well, let's take a shot at this! There is a paper present sensor in these things. I can't tell you exactly where it is, but it will be in the paper path, somewhere. Check for this and make sure that there isn't any dust, paper scraps or similar causing problems. Also, make sure that it hasn't been broken or come loose from it's mounting.
Sure hope this helps!
Jan 23, 2007 | HP Photosmart 8250 InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
