Question about Linksys Wireless-G WRT54G Router
Connection trouble When i plug in a connection into the second port I lose wirless connection why is this happening?
I purchased linksys WRT54G when I connect the second wiring I
lose my internet. My wireless use to work but since I disconneted it and reconnected the wireless does not work.
Posted on Jul 14, 2008
96 grand am turns on then turns off after 5 seconds
Hello! during that 5 seconds, is the Check engine light on? If it is borrow a scan tool and plug it into the On Board Diagnostic Port (OBDII)...It is located on the driver's side, underneath dashboard,between the driver-side door and steering column area...A scan will give a trouble code...Without that code the problem could be any number of causes...Vehicle is losing either spark or fuel...My guess would be fuel...And the cause ( educated guess) would be a defective Idle Air Control (IAC)...Send a trouble code and I'll fix your Pontiac...Guru...saailer
May 07, 2012 | Cars & Trucks
Hi i have a wirless mouse here and i dont know how to use it i bought it from a second hand store
Just plug in your mouse receiver on PC's USB port and play your mouse. It is easy and simple.
Dec 14, 2010 | Dell Computers & Internet
How do I set up a wirless network when this modem doesn't have a second ethernet port?
Usually for this situation it helps to have a wireless route with extra ethernet ports. Where you would have to connect the modem to the wireless router and extra ethernet lines could be shared through the wireless router. Else you would need an ethernet switch for your modem.
May 26, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Cant connect my xbox to internet. i have a motorola sb5100 motem and i lose it at internet connection
Try getting a wireless adapter or a wirless router and buy a ethernet cable plug into the back of your x box 360 console tou get it working add me if u do on (XXXLONG HORN666)
Jan 22, 2010 | Microsoft Video Game Consoles & Games
Whhy Does It Say IP Adress Invailed When I Try To Connect Wirless
it is the same thing that happens with anything that is wireless it just happens. you can fix it by restoring to factory and setting up initially to the wireless. warning you will lose your saved data.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
I want to use a second wifi router as an access point for my XBox
It might be better if you just get a 25-100 foot eathernet cable so you do not have to mess with a second wirless network system a may be a eathernet switch box.
Jan 04, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
My sister has a Motorola SP4200 router with a Netgear WPN824v2 wireless router/accesspoint/switch connected to it. Previously she had the SP4200 connected to port 1 (not WAN) port on the Netgear as it is...
it might be asking for a WEP password in order for you to use it which is on the botom of the router or the game sistem is the one causing the trouble and should not be conected to any wirless or eathernet internet routers.
Jan 03, 2009 | Computers & Internet
Wireless adpater red!
try using WEP encryption, especially if you use a G router, as thid is easier for the adapter to work with then WPA. also make sure that you have the ports open for xbox Live, i think its ports 88 and 3074
Jun 30, 2008 | Microsoft Wireless Network Adapter Xbox...
Linksys Wireless-G WRT54G Router Logo
77 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
