Question about Zeiss 528013 / 528015 Diascope 85
Zeiss diascope coarse adjustment
On my last outing to Yellowstone I noticed that the coarse adjustment knob on my scope was spinning freely. There is a super small hole in both the coarse and fine adjustment knobs. Did I lose a very tiny screw or how do I tighten things down so that the coarse adjustment works again?
  • 1,512 Answers
Sounds like you lost the locking Allen screw.
need that to sort your problem.
Posted on Jul 11, 2008
  • Graeme Ross
    Graeme Ross Jul 11, 2008
    I would suggest taking the scope to an optics repair shop. They should be able to supply and fit a screw to that while you wait. Unless... there is some internal damage to the drive. Then repairs may be a little more involved.
    regards
    robotek
Zeiss conquest parallax knob slips
Zeiss has a lifetime warranty on their conquest line. Contact Carl Zeiss Welcome ZEISS United States
Nov 15, 2014 | Zeiss Conquest 6.5-20x50 Hunting Turret...
How do you adjust the sights on a zeiss 3.5x10x50 rapid z 800
You will not detect any changes as you view through the scope. Only the impact point on your target downrange should change.
Jan 25, 2013 | Zeiss Optics
On my ziess conquest, what turning knobs do what? which one makes it go up and down and which one makes it go left and right?
The top knob should be marked with a "U" and an arrow pointing clockwise. Turning this knob clockwise should adjust point of impact Up, and turning it counter-clockwise should move it Down.
The knob on the side should be marked with a "R" and an arrow pointing clockwise. Turning this knob clockwise should adjust the point of impact Right, and counter-clockwise is Left.
Nov 09, 2010 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
The stage slides down on its own and the view gets out of focus.
Just inside the coarse focus knob you will see a "chrome" ring with holes it it. That ring needs to be tightened just a bit. It will make the coarse focus knob stiffer so tighten only enough to stop the downward drift of the stage. A funny looking tool should have come with the scope. It is used to adjust this "tension" ring.
Oct 22, 2010 | Swift M2251C Monocular Microscope
The focus knobs drift
Oct 13, 2010 | National Optical 138-MS Monocular...
Stage slides down after focusing
There is a tension adjustment for this. It is located on the coarse focus knob which is on the same side as the switch. It looks like a chrome ring with about 3 holes in it. A strange looking tool should have come with the scope. It is designed to fit into these holes and allow you to adjust the tension on the coarse focus knob. You need to tighten it just a little bit. Not too much or you will have trouble operating the coarse focus knobs smoothly.
Jul 08, 2010 | Swift M2251C Monocular Microscope
Swift microscope no 634008 having problem staying in focus when switching magnification
First, a scope of this grade will not be completely in focus as you move from one magnification to the next. But it should be close enough that you do not loose your point of interest.
Be sure you are not pressing down on the stage specimen platform as you change magnifications. It is very sensitive to pressure. Also, be sure that the coarse focus tension is tight enough that the platform is not drifting down imperceptibly as switch magnifications. Look through the scope and watch if the image goes out of focus while you are watching it. If so, you have what is called "stage drift". This is corrected by tightening the tension on the coarse focus knob.
The tension adjustment is on the coase focus shaft. It looks like a chrome ring with about 3 holes in it. There should have been a strange looking tool that came with your scope. It is used to adjust the tension. If your specimen is "drifting" out of focus, simply tighten the tension ring a little bit at a time until the specimen no longer goes out of focus. Do not get it so tight that it is not easy to operate the coarse focus knob.
May 22, 2010 | Swift M2251C Monocular Microscope
How do I fix a mechanical stage from ''drifting'' downwards? Won't stay in position.I move the stage up into position under the objectives but as soon as I let go of the knob the stage drifts right back...
You need to tighten the coarse adjustment so it generates enough friction to keep the stage in place. How to tighten it will vary from scope to scope, but most just have the screws on the knob (metal circle inside the knob with two holes in it). To adjust this type, you'll need a special key wrench.
Feb 03, 2010 | Science & Laboratory
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
New Zeiss 2.5-8 Conquest MC Riflescope. Elevation clickstop adjus
Tried google for zeiss rifle scopes I just did and see they have a suport division...try there and get it from the horsies mouth!!!
Jun 07, 2009 | Conquest Zeiss 3.5-10x50 Mc Rifle Scope :...
Zeiss 528013 / 528015 Diascope 85 Logo
138 people viewed this question
Top Zeiss Optics Experts
Piyal Perera
Piyal Perera
Mark Campeau
Level 1 Expert
Are you a Zeiss Optic Expert? Answer questions, earn points and help others
