Unit will not shut off by itself.
I have a Coleman furnace/ac inside unit in a mobile home, that works fine, but will not shut off by itself. The thermostat was tested and is fine. We have had 2 repairmen out to look at it and they can't seem to fix the problem. The relay was replaced and the outside unit (Carrier) was cleaned. Please help!!!!!
A/C only will not shut off would check for low refrigerant charge. If furnace also will not shut off (remember fan will run for short time before shutting down) then either thermostat is wired wrong or control board is defective
Posted on Jul 11, 2008
Have an older Coleman mobile home furnace (Mdl 8665D766). Both blower fan and booster motor work fine; however, during heating, booster motor will keep constantly running after system cycles through
The booster motor? Do you mean the inducer motor that helps push the exhaust? If the inducer motor won't shut off when the thermostat is satisfied and everything else does shut off, it sounds like the contacts on the relay that powers the inducer are at fault
Feb 03, 2018 | Coleman Heating & Cooling
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Dgaa056bdtb
The relay on the outside unit is stuck
May 25, 2013 | Coleman 3.5 Ton 13 SEER Complete Split...
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
Mobile home furnace with central air unit water coming out of fur
You had the condensate from the furnace come loose look for a pvc pipe coming off the furnace it drains the high efficiency heater. I would really check out your hot water heater too.
Nov 25, 2008 | Heating & Cooling
Duo therm AC/ furnace in Puma not kicking on
there is a "control unit" inside the bottom cover of the A/C on your cealing ... inside there is the control box that controls itself. Has a silver peice bout 2'' thick and the size of a quarter this is your freeze control, if your A/C gets TOO cold and might damage itself it kicks on and shuts down your unit(yes even your furnace) need to have a tech come out and fix/replace it, RV Tech, most A/C repair companies know NOTHING about RV's
Nov 17, 2008 | Dometic Rooftop RV Air Conditioner
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
