cannot initiate a call due to problems in voice library-system error number 105cannot initiate a call due to problems in voice library-system error number 105
You can't post conmments that contain an email address.
Since you are here you have internet connection. Best solutions for network errors and problems is do a web search for the error. here is one solution for the problem.
Two possible solutions. Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
I recommend that you download an error message identifier program to properly identify the problem. You can Google search for one but I use a program called ErrorMsg and it can be found here:
http://www.favessoft.com/index.html
Using the ErrorMsg program it reads "The previous ownership of this semaphore has ended" for error code 105. I don't know if that means there is no software installed to run it or a trial period has ended. But if you do not have an audio program installed then go to idt.com and you can download one.
Also you may have accidentally uninstalled the audio software. If that is the case then you need to restore it by going to: 1. Start Menu 2. Control Panel 3. System and Security 4. Backup and Restore
If these solutions still do not work then re-post your question and include the Operating system you are running (Mac, Windows, Linux, Ubuntu) and the laptop make and model so we can pinpoint your exact problem.
Cause: Error 105 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
Solution: To repair Error 105 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.
How Do I Fix Error "105"? (Instructions)
A voice call is simply the total opposite of a text message.
During a voice call, you dial the actual number on your pad, and you press the send button as well. this will initiate a (voice call). During the voice call, you are able to verbally express words to the other party, or recipient, via digital transfer. On most Samsung, you can initiate the VC, by typing the number, then pressing the voice call button on the touch screen to initiate the call. Pressing the voice call button is the same as pressing the send button after you enter the number of the recipient.
SQLDumper is used to collect stack information and debug information in case SQL Server crashes. The dump that is created out of this is normally send to Microsoft and is used by the development team to debug problems (not that you can elect not to send this information to Microsoft).
The error above means that likely your SQL Server installation is corrupt, so I would suggest that you reinstall SQLServer.
First u activate ur microphone connection.Click on Start - Settings - Control Panel - Sound and audio device Propeties - Advanced - Options - Properties - Select Mic in volume and check it.
